Can I hide "object manipulation" in PS?
tdk408
(@tdk408)
I use the "sliced info"at the bottom of the sidebar many times a day.
That valuable info is pushed off the bottom of my screen by "object manipulation" which I use very rarely.
It is a minor irritation, but I have scrolled down hundreds of times, and I'd rather avoid that. Is there a setting or XML file I can edit?
THANKS!
Tom
Best Answer by Walter Layher:
If you unselect the currently selected object, e.g. by clicking on the background of the print plate, the "object manipulation" will disappear.
Opublikowany : 13/12/2024 7:41 pm
Walter Layher
(@walter-layher)
RE: Can I hide "object manipulation" in PS?
Opublikowany : 13/12/2024 8:46 pm
