        2.7.2 Issues with Sovol SV04
I have several designs that use an ellipse as a base. With 2.7.1, the ellipse is printed as a whole shape and I have no first layer adhesion issues. After upgrading to 2.7.2, I encountered multiple issues when slicing the same .obj file:
- skirt is totally wrong, prints about half size and offset from actual ellipse
 - elipse is printed in multi-segments, with each segment printed in alternating 45 degree directions
 - first layer adhesion fails at about the third segment
I re-loaded 2.7.1, resliced the same object file, and the print is perfect - skirt is fine, ellipse is printed as a whole object, and first layer adhesion is normal
So, it appears there are major bugs with the Sovol SV04 version of 2.7.2. I will continue using 2.7.1 until there is evidence that these problems have been fixed.
                            Posted : 06/03/2024 11:30 pm
