BIQU build sheet - 300x300 compatible
darksharpie
(@darksharpie)
In case anyone is wondering, the "300x300" mm BIQU Cryogrip Pro Frostbite for Voron 300/QIDI Plus4 fits on the L - but barely.  You have to carefully position it slightly biased to the left so it doesn't contact the spool holder screws.  But it's another build sheet option (I really like these for PETG and PLA on my other Prusas).
Napsal : 13/11/2025 1:33 am
4 lidem se líbí
Dtmpts
(@dtmpts)
RE: BIQU build sheet - 300x300 compatible
Any chance of a picture showing fitment?
Napsal : 16/11/2025 12:37 pm
GreenPea
(@greenpea)
Posted by: @darksharpie
I  guess you would be able to remove some material on the right side where the screws are? Seems like a few minutes with a dremel?
Loving the learning curve!
Napsal : 17/11/2025 7:15 am
darksharpie
(@darksharpie)
Posted by: @dtmpts
Napsal : 23/11/2025 2:57 am
1 lidem se líbí
Dtmpts
(@dtmpts)
Thanks 👍
Does the C1L just do bed probing as normal when using this one?
Napsal : 04/12/2025 4:55 am
1 lidem se líbí
darksharpie
(@darksharpie)
Yes.  No difference I can tell from the printer's perspective.
Posted by: @dtmpts
Thanks 👍
Napsal : 06/12/2025 2:59 pm
1 lidem se líbí
Alienbliep
(@alienbliep)
Since the Biqu Glacier Pro is my favorite. Everything sticks like an frog on glass on it.
I ordered one for an voron 300x300 and made the back indents myself.
Detecting steel sheet is just on the edge of one of the honeycomb holes in the front, but i think you can alter it in the g-code.
Fits like a glove.
I have to mention i have the side spool holder removed since i don't use it.
I put the satin sheet on top off this one (sideways in the middle) and with an very point thing scratched the blue buildplate.
Took and dremel and very carefully cut out the holes.
Applied some clear coat on the bare steel afterwards
This post was modified před 5 months by Alienbliep
Napsal : 05/02/2026 1:11 pm
1 lidem se líbí
Ahr0uN
(@ahr0un)
K1 max plate from biqu ? anyone?
Napsal : 05/02/2026 4:52 pm
