my linear rail is squeaking
Mramonette
(@mramonette)
Mitglied
Do we have instructions on how to lubricate the linear rails on Core One L ?
Veröffentlicht : 17/03/2026 3:28 am
Same Old Shane
(@same-old-shane)
Mitglied Admin
RE: my linear rail is squeaking
The not so easy answer, is that you could use the XL help doc on the linear rails as a guide and find the same locations on the Core One L.
https://help.prusa3d.com/guide/how-to-lubricate-linear-bearing-rails-xl_384273
On the flip side, I sent this over to our product guide team and requested a help doc created for the core one / + / L and linear rail maintenance.
Shane (AKA FromPrusa)
Veröffentlicht : 17/03/2026 5:00 am
Maker Hoot
(@maker-hoot)
Mitglied
I may have a similar issue, the printer squeaks loudly when the head moves towards the front. The sound seems to come from the block with the pulleys and gears on the right side that transits around. Is this more likely a rail lubrication issue or something inside the belt pulleys?
Veröffentlicht : 05/04/2026 2:19 am
REB
 REB
(@reb-3)
Posted by: @maker-hoot
I had a similar noise on my Core One.  After some investigating I discovered the squeak was worse when one belt was moving at high speed and the other belt was mostly stationary, it didn't matter which belt was moving and which on was not.  I determined the squeak was coming from where the two pulleys in the rear block contact each other with the small washer between them.  I put a small amount of lube on the washer and the noise went away.
Veröffentlicht : 18/05/2026 3:20 pm
