x-axis belt riding on pulley
langjai
(@langjai)
Posting this to see if anyone is experiencing this problem. It looks like some kind of misalignment. It seems like the belt is being worn down. Hope someone has a simple fix, although I'm guessing I'll need to be disassembling the printer.
https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/09/17111635-core-one-x-belt-issue.mp4
Opublikowany : 24/09/2025 1:26 am
RE: x-axis belt riding on pulley
Posted by: @langjai
Could you provide more detail like photos of how the belts are routed? Also, check that the X and Y axis motor pulleys are correctly set and oriented as here: Installing the X-axis pulley
Opublikowany : 24/09/2025 1:34 am
langjai
(@langjai)
I chatted with support and it looks like I installed the x-axis timing pulley wrong.  🙁  Apparently I installed it upside-down. The x-belt is toast. They're sending me a replacement.
https://help.prusa3d.com/guide/5-corexy-assembly_835522#843284
Opublikowany : 24/09/2025 2:49 am
1 ludzie polubili
