How to increase printer software limits Chamber Max Temp
AL
 AL
(@al-2)
I have this chamber heater I made and the goal is to get to 65C chambe temperature. However, when ever the chamber themistory reaches 60C the printer puts up this message about excessive temperatures and turns on the chamber fans until it drops to 55C.
I suspect the printer would be completley fine at 65C, so for that reason I don't want this feature to activate until 70C. How would I even go about changing this? I don't see anything in printer settings, so I am assuming it would have to be deeper than that. I thought I would ask because atp I have no idea.
https://www.printables.com/model/1445294-air-manager-active-chamber-heater-and-filter-v05
Opublikowany : 19/04/2026 2:14 am
RE: How to increase printer software limits Chamber Max Temp
Posted by: @al-2
Your options are to downgrade to 6.4.0 or patch the 6.5.3 firmware to raise the maximum temperatures. 6.5.3 lowered the max chamber temperatures by 10°
Opublikowany : 19/04/2026 2:20 am
