How do we setup PrUSA Link to our Prusa Slicer?
NickAtNight
(@nickatnight)
It seems that PRUSA Connect is down this morning. So I cannot use that route to drop my file on my printer from Prusa Slicer.
I realized that I had never setup PRUSA Link on my Computer (only on my phone)... {{and I have to recover all my LinkSys logins first, cause I had not reset those since I got the new computer}}
So in Prusa slicers, we go to Prusa Connect, then we  Select a printer, then setup a printer.
(getting a string did not match the expected pattern if I put in SN*******)
Now it wants a Code.
   - Where do we get the code and what is the format (presumably from the silver tag on the back of the machine)
Best Answer by NickAtNight:
Thanks to PrusaSUPPORT - it was an Apple Security issue.
Go to SETTINGS
.. then Privacy and Security
.. .. then Local Network
.. .. .. then turn on PrusaSlicer so that it can find and
          communicate with devices on my local network.
Now the Test works !
Veröffentlicht : 13/12/2025 8:01 pm
RE: How do we setup PrUSA Link to our Prusa Slicer?
I'm not in front of my printer, but you should be able to get the API code from the firmware in UI. Probably under network settings. Prusa Connect is working for me so getting the API key from there is usually easier.
Veröffentlicht : 13/12/2025 8:22 pm
NickAtNight
(@nickatnight)
In the Browser:
  We enter the IPv4 Address:  Found in the PRUSALINK submenu
      (pretty sure I had to log-in.  But I don't see a log-in/log-out now that it is setup)
  It has two tabs:  Dashboard and Storage
        So I can drag and drop my G-code here
        And I can manage the Storage on the USB drive
In PRUSA Slicer,
Go to Printers
  Complete the printer info:
    Give the printer a descriptive name
    Select Host type:  PrusaLink
    Enter Hostname, IP or URL:  Presumably the IPv4Address
    Authorization type:  API key (?)
    API Key/ Password.
Posted by: @nickatnight
Veröffentlicht : 14/12/2025 6:59 pm
In Prusa Connect, select the printer, goto settings then scroll down to get the API key for PrusaLink:
Veröffentlicht : 14/12/2025 7:09 pm
NickAtNight
(@nickatnight)
Go to SETTINGS
Veröffentlicht : 14/12/2025 9:43 pm
