Core One screen flickering / black screen
Pagina 1 / 5
Linus
(@linus)
Hi there,
I have had my Core One for exactly one week now, and since a few days ago the screen started behaving weird: The screen partially turns black/white, shows the image mirrored, or - most of the time - is completely black.
I already contacted support about this, but I was wondering if anyone else experiences the same issue?
Postato : 14/04/2025 10:11 pm
Brian
(@brian-12)
RE: Core One screen flickering / black screen
I assume you've checked to make sure the cable and ground are not loose?
Postato : 15/04/2025 12:49 am
1 persone hanno apprezzato
Linus
(@linus)
Posted by: @brian-12
I've checked and cleaned both cable and ground with compressed air, but the issue still persists 🙁
Postato : 15/04/2025 10:50 am
LarGriff
(@largriff)
Posted by: @linus
Did you check both ends of the cables?  The other ends are inside the xBuddy box.  At least two other people here have reported similar symptoms that were resolved by reseating the orange plugs on the ribbon cable.  Do this with the power turned OFF, of course, and be careful with the alignment.
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Postato : 15/04/2025 12:59 pm
Valerio banda
(@valerio-banda)
Utenti
Anch'io ho lo stesso problema, la stampante funziona bene ma il display no.
I'll try to check the cables again
Questo post è stato modificato 10 months fa da Valerio banda
Postato : 19/04/2025 12:10 pm
mirek454
(@mirek454)
The same thing happened to me yesterday. I disconnected and reconnected both ends of the display ribbon cable, checked the ground wire connection. After restarting, it blinks again. Finally, I disconnected the supplied flash and the problem is gone. I am now using my new flash and it works without any problems. I recommend trying it and let me know the result.
Please excuse my writing style.
I am from the Czech Republic, I don't speak English, I translate using Google Translate
Postato : 22/04/2025 7:41 am
Linus
(@linus)
What orange plugs do you mean exatly? I tried reseating the red plugs from the ribbon cables on the xBuddy board aswell as on the LCD board. I also changed the flash drive.
Reflashing the firmware and resetting the printer helped for two days, then the issue came back.
Unfortunately I bought the printer not directly from Prusa, but through a reseller. The reseller is taking forever in replying and sending me replacement parts, and Prusa won't do anything, because I haven't bought it through their shop. I'm desperate in solving this issue, I really want my printer to work 🙁
If anyone has any idea what to try aswell, please let me know!
Postato : 23/04/2025 3:18 pm
Kyosuke_14
(@kyosuke_14)
I have a similar problem.
https://www.youtube.com/shorts/09zQmQsrnHw
Postato : 24/04/2025 8:47 pm
VW
 VW
(@vw)
Utenti
Made an account to post what worked for me - found it here https://forum.prusa3d.com/forum/postid/738415/ for the mk4s that also worked for the Core One
Going into settings>hardware>screen refresh rate and setting it to low has done the trick. No more flickering!
It took a bit to go through the menus with the screen going black, but moving the selection slowly, and just waiting for the screen to eventually load when it did go dark got me there in the end.
Hope this helps!
Postato : 02/05/2025 3:05 am
4 persone hanno apprezzato
Mastakko
(@mastakko)
Utenti
Mine goes completely blank after startup, like your video after you've scrolled the menu a bit but without flashing.
Postato : 04/05/2025 2:07 am
Mastakko
(@mastakko)
Utenti
Your screen was flickering, was it ever completely black/blank?
Posted by: @vw
Hope this helps!
Postato : 04/05/2025 2:08 am
VW
 VW
(@vw)
Utenti
It was the same in the video. The screen did go black on occasion. It stayed black at times seemingly if the screen tried to display certain menus.
Navigating the menus/scrolling up and down with the black screen usually eventually led the screen to flicker back on just long enough to see where to go next. Without a USB and from memory it was 3 clockwise turns before you hit the settings menu, which may give your screen a chance to reload? Other times i'd just leave it for 5 minutes and eventually it'll load, but once you load anything else on the screen it was back to flickering.
Postato : 06/05/2025 11:09 pm
Elmo
 Elmo
(@elmo-2)
Hi
I changed the USB Prusa to USB Sandisk. So far the problem has not recurred.
Postato : 28/05/2025 8:18 pm
RogerWilco75
(@rogerwilco75)
I have the same problem. It was flickering during prints but now after flashing the new firmware it turns immediately black. I thought it wad a good idea to update to 6.3.3 instead now both homing and display are a mess. I'm really disappointed. Cables are ok...obviously. Tomorrow I will chat again with support that today suggested to disconnect and reconnect both side of the display cable!?
Postato : 28/05/2025 9:41 pm
RogerWilco75
(@rogerwilco75)
Posted by: @rogerwilco75
I rolled back to firmware 6.3.2 from Prusa Connect and then set the refresh rate of the display to LOW. Now it seems to work properly.
Postato : 28/05/2025 10:21 pm
Elmo
 Elmo
(@elmo-2)
Unfortunately, the problem with the screen continues ☹️
Posted by: @elmo-2
Hi
Postato : 29/05/2025 5:55 pm
polymath86
(@polymath86)
Utenti
I received my Core One a week ago and updated to 6.3.2. the screen has been flickering and seemingly restarting (it returns to the main menu every time I try to patiently navigate to change the screen refresh rate or factory reset). It is very frustrating and seems to be getting worse.
Postato : 31/05/2025 1:19 pm
Elmo
 Elmo
(@elmo-2)
On Thursday, I spoke with technical support. I sent them a video of the problem. They were supposed to respond on Saturday. So far they have not written anything back
Posted by: @polymath86
Postato : 01/06/2025 4:39 pm
Elmo
 Elmo
(@elmo-2)
Kazisvět VI
(@kazisvet-vi)
Utenti
Same problem with my new MK4S. Maybe should resolve change setting with flash to low in settings but i can't get it throuhg black flashing screen. Support told me that it depends on enviroment where printer take place. I will try reconect data cable straight from printer to display away from other cables. Maybe this should be better to get on this setting on printer.
Postato : 01/06/2025 8:21 pm
Pagina 1 / 5
