What filament dryer to use?
Stránka 3 / 3
Crab
 Crab
(@crab)
RE: What filament dryer to use?
Since I can't edit a post, here is some additional info. I had two PolyDryer units. I tested both and included some of the Serial # to identify each. So you'll see 4 plots for the PolyDryer, 2 from each unit. They were purchased a few months apart. The humidy sensor in them is accurate but it reads very high while drying due to the heated, moist air. It is accurate about 2 hours after heating is turned off and the seals are reinserted into the base of the case.
Napsal : 21/09/2025 2:51 pm
Here is an interesting take on drying filament... Use the microwave: Drying Filament in a Microwave: Fast Solution or Fire Hazard?
Not sure I want to try this however.
"Some filaments feel the rain, others just get wet"
- Bob Marley
Napsal : 21/09/2025 7:41 pm
mark
 mark
(@mark)
Posted by: @hyiger
NOPE. There is a comment a ways down that sums it up. Hot spots! Microwave heating is not even, and depends on the water content of the material. It could develop hot spots. If you are someone who characterizes their dryer with thermocouples, double NOPE. Have some patience. Get a dryer that holds a few spools and plan ahead to dry what you are using the next day or two at the recommended settings.
Regards,
Mark
Napsal : 21/09/2025 9:07 pm
I just posted this as an amusing article. For myself I use the Creality Pi X4 which can handle Nylon which is my primary filament at the moment. Need to pick up an air fryer to use as an annealer since I'm currently using my (expensive) SMD reflow oven...
- Bob Marley
Napsal : 21/09/2025 9:50 pm
Robin_13
(@robin_13)
I purchased a food dehydrator instead of a dedicated dryer and store my filament in sealed boxes with desiccant.  Keep humidity around 15% at 22 degrees.  What I have read, if you need to dry higher temperature filaments with a dryer that won't go the recommended temperature, you just need more time.  Post drying storage is more important.  Take filament out of dryer and put into  storage bin.  I just purchased a Sterilite brand of storage bin that has seals in the lid already and it seems to work pretty good.  Nice solid snaps on the lid.
Napsal : 21/09/2025 10:17 pm
Chocki
(@chocki)
Yeah storage is important. Once my filament is dry and I am not printing with it, I keep it in a ClipLok box with bags of desiccant.
Napsal : 22/09/2025 3:03 pm
Cédric
(@cedric)
Posted by: @hyiger
It works really well for a super quick drying, i used it multiple times, then threw them in for a bit of normal drying in my food dehydrator based dryer before pritning. Just be careful not to run it to long, i made a brick out of a PETG roll once, PCCF was much easier, just remove the RFID tag thing in the roll 🙂 The roll dryes from the outside, so for small prints you can get it ready in no time, but to dry the complete spool to the core i would probably just leave the rolls in the dryer instead for a bunch of hours, it all depends on the size of the prints.
Napsal : 23/09/2025 7:58 am
Crab
 Crab
(@crab)
A follow up:  I sent my temperature results (previous post in this thread) to Polydryer and I got a number of replies from their product management/testing team. They said that the most important item in drying filament is the airflow. And the airflow in the Polydryer is very good. It has a separate output port on one side and an exhaust on the other. I don't use ASA/Nylon to know if other dryers are more effective at drying. Polymaker also assured me if it didn't perform as I needed on any of their recommended filaments that they would replace. This is excellent customer service compared to Sunlu who provide zero customer service. I am very happy with the Polydryer system and it gives me a better workflow, for my use, than any other dryer solution.. given that I use exclusively PLA/PETG/TPU.
Napsal : 24/09/2025 1:21 pm
1 lidem se líbí
Posted by: @crab
If you are happy with it then most definitely stick with it. For me it was 18+ hr drying time they recommended for Nylon was a bit much for me. Again though, I have a lot of their dry boxes so that part of it I really like.
- Bob Marley
Napsal : 24/09/2025 1:56 pm
1 lidem se líbí
Artur5
(@artur5)
According to Sunlu 2-4 hours at 90C is OK for drying PA12, but you need 10-12 hous at 70C.
 PrintDry recommends more than 12 hours at 85C for PA,  Fillamentum says a minimum of 3 hours at 80C and Prusa 6 hours at 90C.
Who is right ?. Make your choice.. 😊
Napsal : 24/09/2025 5:44 pm
Posted by: @artur5
The problem with the Polymaker dryer that @crab is using, it only hits 50-60C. So for Nylon it'll take (according to Polymaker for that model dryer) 18+ hours for PA. Anyway, I put Nylon/PA in my Creality drier overnight for 8hrs. I did have one problem with a off-brand PA filament (forget the name) where the spool melted in the dryer. The filament was fine...
- Bob Marley
Napsal : 24/09/2025 5:55 pm
Artur5
(@artur5)
Of course the correct time depends, apart from the temperature inside the drier, on the amount of moisture that  the filament has absorbed.  If the spool is kept all the time in a sealed or vacuum container with silica gel, probably 4-6 hours at 80C is enough. If that PA has been left in the open for days, it will take possibly more than 24 hours, even at 80C.
From what manufacturers like Prusa, Fillamentum or Sunlu say, it seems that PA or PC need driers that reach 75C or above. At 55-60C, it would take literally several days. That's a waste of time and not practical at all.
Napsal : 24/09/2025 8:17 pm
Posted by: @artur5
I keep my PA in a dry box with activated alumina at 10% humidity and pop it in the dryer at 80C for 6 hrs. Works well for me.
- Bob Marley
Napsal : 25/09/2025 12:49 am
Stránka 3 / 3
