Any reason not to use a switched UPS outlet, and UPS VA sizing…
Mchad65
(@mchad65)
Will using the switched outlet on an UPS to power on/off my Core One be bad for the unit in any way? And will a 700va UPS be adequate for momentary power flickers that typically happen during Florida thunderstorms? Don’t intend to keep printing for hours during any outages, only saving a print during a momentary flicker. Thanks.
Veröffentlicht : 01/12/2025 12:34 pm
chmax
(@chmax)
RE: Any reason not to use a switched UPS outlet, and UPS VA sizing…
Given that the power off/on switch does exactly the same thing, I do not see why this would make a difference and, if you search im other posts in the forum you will see that there a a lot of us doing exactly that to remotely turn on/off the printer with all kinds of switchable outlets.
w/r to the wattage needed, I will let someone else answer that as I can't...
Veröffentlicht : 01/12/2025 8:08 pm
Mchad65
(@mchad65)
Posted by: @chmax
Thanks for that. I just like to double check in case there's something I didn't think of. But this is a relatively simple device so, yeah.
Veröffentlicht : 01/12/2025 10:05 pm
Walter Layher
(@walter-layher)
There is an article about UPS devices for 3D printers here. It mentions especially to use devices with "line interactive technology." I guess the other ones would react too slowly and the print would be lost anyway. As for the capacity a UPS with 700 VA is perhaps enough for short interruptions. The table in the article mentions running times for the printer with the UPS and the required capacity for longer running times.
Veröffentlicht : 01/12/2025 10:26 pm
Curious though. Is Power Panic not supported on the Core One?
Power Panic
According to the comments on this page, it appears it doesn't function as intended on the C1
Veröffentlicht : 01/12/2025 10:33 pm
OK, so I just tested the Power Panic feature and it does work. I started a print then pulled the mains plug from the socket. The head moved to the left. After plugging back in, the head homed on the front left corner, then right and the print resumed. Note, this won't work if you turn it off from the PSU switch (which makes sense).
Veröffentlicht : 01/12/2025 10:46 pm
mark
 mark
(@mark)
I can confirm on my Prusa Mini that a typical UPS takes too long to switch and the print is lost anyway. I have not tried yet on my Core One but expect similar results. You do indeed need a UPS that provides constant power with little to no switching time.
Regards,
Mark
Veröffentlicht : 02/12/2025 10:40 am
chmax
(@chmax)
I didn't ever tried it with my 3d printer but I've been using an APC RS550 ups for years to cover my NAS and rounter. The NAS is particularly sensitive to power losses and it never ever complained about a transient. The RS550 has a max draw of 330W and it is too close to the current a core one draws, measured by others on the internet, between 300 to 330W when heating in a cold environment. If I were to buy one to cover your scenario I'd go for the RS900 series having 540W of max draw.
Veröffentlicht : 02/12/2025 11:16 am
Mchad65
(@mchad65)
Posted by: @chmax
I think I read somewhere here that for a normal UPS to protect the unit while printing you need to disable power panic. But I just tested PP and honestly, it worked flawlessly. The printer shut down, and as soon as power was reapplied, it homed, and heated - then resumed. I couldn't find any imperfection in the print. Pretty cool. However I still may look for a fast switching UPS just because...
Veröffentlicht : 02/12/2025 4:27 pm
