A Summary of Core One support questions on these forums
Disclaimer: I used Claude AI to scrape all the forum posts in two sub-forums and create a report. Kind of interesting but didn't really tell me anything new that I didn't already intuit. Where it says "I pulled" or "I did X" that is Claude, not me.
Core One support issues: what 1,094 threads actually tell us
I pulled the full topic list from both Core One troubleshooting subforums (Assembly and first prints troubleshooting and Hardware, firmware and software help) — 1,094 unique threads, 11,518 posts, ~2.1M total views as of April 2026 — and classified every thread by issue type. Sharing the aggregate picture in case it's useful for anyone deciding between the kit and the factory-assembled unit, or just trying to anticipate where they're likely to spend time.
Caveats up front: title-only classification (I didn't read 11k posts), ~3% genuinely vague titles couldn't be classified, and there's no sales-figure denominator to turn these into rates per printer sold. This is a topic-volume distribution, not a failure-rate study.
Where the support volume actually goes
| Category | Threads | Replies-weighted | Views-weighted |
| Motion / gantry / belts / shifts | 17.3% | 21.4% | 19.1% |
| Extruder / hotend / extrusion | 16.5% | 13.4% | 14.0% |
| Firmware / software / connectivity | 14.4% | 11.6% | 12.1% |
| Bed / adhesion / first layer | 7.5% | 6.3% | 5.2% |
| Print quality defects | 7.5% | 17.4% | 16.9% |
| Enclosure / chamber / doors / camera | 6.9% | 3.8% | 5.1% |
| Electrical / boards / sensors | 6.1% | 3.9% | 4.6% |
| Filament handling / MMU | 4.8% | 3.1% | 3.6% |
| Assembly / build process | 4.0% | 3.5% | 3.6% |
| Meta / how-to / slicer / other | ~11% | ~5% | ~6% |
| Calibration | 2.0% | 6.7% | 7.2% |
| Noise / sound | 1.6% | 2.0% | 1.4% |
Two things jump out from the reply-weighted column:
- Print Quality is 7.5% of threads but 17.4% of replies — almost entirely because of VFA Artifacts on X+Y Straight Edges (1,286 posts). Strip that one thread and the category is roughly proportional.
- Calibration is 2.0% of threads but 6.7% of replies — mean 32.8 posts per thread, the highest of any category. Small-N, high-intensity, driven by threads like Failed Y-calibration of a new CoreOne (420 posts) and Constantly recalibrating (92 posts).
Motion/gantry is the single biggest category on every measure. This is where Core One owners spend the most time.
The Assembly vs Hardware subforum split — the clearest structural signal
This is the closest proxy I have for kit-leaning vs. factory-leaning populations, since most titles don't self-identify. The two subforums are used for very different stages of ownership, and the category mix reflects that:
| Category | Assembly subforum | Hardware subforum |
| Motion / gantry / belts / shifts | 21.9% | 14.2% |
| Bed / adhesion / first layer | 11.3% | 5.0% |
| Print quality defects | 11.1% | 5.1% |
| Assembly / build process | 7.4% | 1.8% |
| Upgrade path (MK3/MK4→Core) | 3.7% | 0.8% |
| Firmware / software | 5.8% | 20.0% |
| Enclosure / chamber / doors / camera | 2.1% | 10.0% |
| Extruder / hotend / extrusion | 17.1% | 16.2% |
Read it as: if you just finished assembling a kit, expect motion and bed/first-layer issues to dominate. If you've been running the printer for a while, firmware and enclosure/accessory issues become the dominant post-commissioning noise.
Extruder, electrical, and filament-handling issues are roughly evenly distributed — these don't care how the printer got assembled.
Kit vs factory: what I could actually extract
Only 6.4% of thread titles (70 of 1,094) contain an explicit kit-vs-factory keyword — the other 93.6% are unmarked without reading the thread body. So the following is a small-N qualitative signal, not a rate comparison.
Explicit signal: 52 kit-identified threads, 18 factory-identified threads.
Within each group, the dominant failure-mode cluster is clearly different:
Kit cluster (52 threads):
- 30.8% are MK3/MK4→CoreOne upgrade-specific failures — Y-axis self-test failures post-upgrade, Z-axis calibration failures, lead-screw travel mismatch between upgrade screws and Core One kit screws, POM-nut reuse warnings, "cables too short in the upgrade kit", "missing boxes in upgrade kit".
- 23.1% are assembly-step-specific problems — "Assembly step 4.30 rear trapezoidal nut", "Step 7 securing the rear motor", "Wrong part included in my kit", "Missing fuses", "Missing steps in the kit manual".
- 21.2% are motion issues on new builds — mostly Y-axis self-test failures.
Factory cluster (18 threads):
- 38.9% are out-of-box quality complaints — "Arrived damaged", "Brand new OUT OF THE BOX PRINTER [issue]", "new assembled Core One - print lucks ugly", "Not the greatest unboxing experience", "New pre-assembled Core One stuck booting halfway", "Pre-assembled unit with extreme under-extrusion problems".
- Individual cases of shipped-with-bad-thermistor, shipped-with-layer-shifts-on-first-benchy, shipped-with-uneven-bed-temps, factory unit that decalibrates during print.
The clean distinction: both groups report Assembly/Build issues at high rates, but the cause is different. Kit threads describe assembly-process problems (step X, wrong part, manual error). Factory threads describe QC-at-delivery problems (arrived broken, bad thermistor, booting stuck, bed temp uneven, layer shifts on first print).
This is consistent with the expected failure modes of each channel — kits surface assembly errors, factory units surface QC escapes — but the fact that ~39% of the explicit-factory threads are out-of-box defect complaints is worth noting if you're evaluating the pre-assembled option. N is small (18), so take the percentage loosely; the qualitative pattern is clean.
The ten mega-threads driving a lot of the noise
If you read nothing else, these are the persistent issues on the Core One. Seven of ten are motion-adjacent.
The VFA thread alone has ~254k views — it's the single biggest gravity well in the Core One support landscape.
Method notes
- Scraped all pages of the two English-language troubleshooting subforums on 2026-04-21.
- 15-category keyword classifier applied to titles (iterated three times, 3.4% residual unclassified).
- "Answered" rate is 12.5% flagged across the dataset, but that's a floor — most resolved threads never get flagged.
- Excluded: General Discussion, How-do-I-print-this, User Mods, Signature Oak.
If anyone wants the raw JSON or the classifier to re-slice this a different way, happy to share. And if you spot miscategorizations in the mega-threads list or the kit/factory clusters, point them out — title-only classification has real blind spots.
RE: A Summary of Core One support questions on these forums
Now that it is "after hours" a more deep dive analysis:
Core One support issues: what 11,381 posts across 1,094 threads actually tell us
Pulled every post from both Core One troubleshooting subforums (Assembly and first prints troubleshooting and Hardware, firmware and software help) — 1,094 threads, 11,381 parseable posts, ~2.1M views as of April 2026 — and read every post, not just titles. Updated this from an earlier title-only version because title-only analysis was producing some misleading conclusions. Sharing the content-based picture in case it's useful for anyone deciding between the kit and the factory-assembled unit.
Caveats up front: 73% of threads still can't be classified as kit vs factory because the author never says either way in the first five posts. Classification of issue category is regex-on-content, not hand-coded. There's no sales-figure denominator, so all percentages below are within-population shares, not per-unit failure rates. With that said —
Where the support volume actually goes (content-based)
| Category | Share of threads | Change vs title-only |
| Motion / gantry / belts | 22.6% | +5.3 pp |
| Firmware / software / connectivity | 13.5% | −0.9 pp |
| Extruder / hotend / extrusion | 9.8% | −6.7 pp |
| Enclosure / chamber / doors / camera | 8.2% | +1.3 pp |
| Bed / adhesion / first layer | 8.0% | +0.5 pp |
| Filament handling / MMU | 7.1% | +2.3 pp |
| Electrical / boards / sensors | 4.8% | −1.3 pp |
| Upgrade path (MK3/MK4→Core) | 3.9% | +2.0 pp |
| Assembly / kit build issues | 3.8% | −0.2 pp |
| Print quality defects | 2.8% | −4.7 pp |
| Noise / sound | 2.4% | +0.8 pp |
| Slicer / profile | 2.2% | −0.6 pp |
| Calibration | 1.7% | −0.3 pp |
| Unclassified | 9.0% | +5.6 pp |
The big shifts from reading content:
- Motion/gantry climbed from 17.3% to 22.6%. Many threads filed under "print quality" or "extrusion" turn out to be belt/Z-axis/resonance problems diagnosed through their symptoms. They belong in Motion.
- Print Quality Defects dropped from 7.5% to 2.8%. Once you read the threads, most visual defects trace back to mechanical root causes. Print Quality is a symptom category, not a cause category.
- Upgrade Path doubled from 1.9% to 3.9%. People don't always say "upgrade" in the title — they open the thread and describe their MK4S conversion in the first paragraph.
Motion/gantry is by far the biggest single category on the Core One. Nearly 1 in 4 support threads.
Kit vs factory — the big reveal after reading content
Title-only analysis had 70 classifiable threads. Reading post content produced 295 classifiable threads — a 4.2× increase in signal coverage. Now there's enough data to compare meaningfully: 187 kit threads and 99 factory threads (69 strong evidence + 30 weaker).
Remaining 73% don't self-identify even in post content. That population is probably factory-skewed (it's the default purchase option) but there's no way to prove it from the data.
| Category | Kit % (N=187) | Factory % (N=99) | Notes |
| Motion / gantry / belts | 29.4% | 31.3% | essentially identical |
| Upgrade path | 21.4% | 2.0% | kit-exclusive (by definition) |
| Extruder / hotend / extrusion | 6.4% | 16.2% | factory 2.5× kit |
| Firmware / software | 6.4% | 10.1% | factory 1.6× kit |
| Assembly / build issues | 9.6% | 3.0% | kit 3× factory |
| Bed / adhesion / first layer | 3.7% | 8.1% | factory 2.2× kit |
| Filament handling / MMU | 7.5% | 6.1% | similar |
| Print quality defects | 1.1% | 4.0% | factory 3.6× kit |
| Electrical / boards / sensors | 4.3% | 2.0% | kit 2× factory |
| Enclosure / chamber / camera | 3.7% | 3.0% | similar |
| Noise / sound | 1.1% | 3.0% | factory 3× kit |
Counter-intuitive finding: factory-assembled units report higher rates of extruder problems, first-layer problems, print quality issues, and noise complaints than kit builds. This runs against the "pre-assembled means it works" assumption. Possible explanation: factory-assembly variance in things that kit builders would end up tuning manually (nozzle torque, belt tension, first-layer offset, fan alignment). Kit builders also tend to know their machine's acoustic signature because they assembled it.
What the title-only analysis got wrong: I previously wrote that factory threads cluster around "arrived damaged / out-of-box defect complaints." Reading the actual thread content, only 1 of 99 factory threads is a shipping-damage complaint. The real factory pattern is a long tail of mechanical teething issues — mostly the same issues kits have, just in different proportions.
What the content analysis confirms: motion/gantry issues hit both populations at essentially the same rate (~30% each). This is a platform-level issue with the Core One's CoreXY + bed-Z architecture, not a kit-vs-factory issue.
Kit owners' real challenge isn't assembly — it's what comes after
Breakdown of root causes within the 187 kit threads (from opening posts):
| Rate | Kit root cause cluster |
| 17.6% | Firmware / connectivity / post-build software |
| 11.8% | Upgrade-specific (MK3/MK4 → Core conversion problems) |
| 8.6% | Belt tension / broken pulley |
| 8.0% | Z-axis assembly (upgrade screws, rods, trapezoidal nut) |
| 4.8% | Linear rail / bearings skewed |
| 4.3% | Bed / first layer on new build |
| 3.7% | Cable/wire/connector routing errors |
| 2.1% | MMU on new kit |
| ~5% combined | Literal assembly errors (missing/wrong parts, manual errors) |
| 34.2% | Miscellaneous / doesn't match any single pattern |
Only ~5% of kit threads are literal assembly errors. The kit experience isn't "hard to put together" — it's "hard to get running once you finish putting it together", especially if you're coming from an MK3/MK4 upgrade where 24.6% of kit threads are upgrade-specific mechanical problems (Z-axis mismatch, POM-nut reuse, lead-screw length differences, missing boxes in the upgrade kit).
Resolution rates (new from reading thread endings)
| Variant | N | Effective resolution rate | No-reply rate |
| Factory (strong evidence) | 69 | 36.2% | 0.0% |
| Factory (weaker evidence) | 30 | 33.3% | 0.0% |
| Kit | 187 | 26.2% | 4.3% |
| Unknown | 799 | 26.2% | 9.8% |
| Overall | 1,094 | 27.0% | 7.9% |
"Effective resolution rate" = threads that either got the Answered flag or ended in clear resolved-language (fixed it / solved / replaced / thanks everyone). The forum's Answered flag alone captures only 12.5%; reading endings more than doubles the detectable resolution rate.
Factory issues resolve more often than kit issues (36.2% vs 26.2%). And factory threads have a 0% no-reply rate — every factory owner gets at least one response, while 4.3% of kit threads get no responses at all. Factory problems tend to be single-defect-plus-RMA with clean closure. Kit problems tend to be iterative debugging without clean endpoints. This is a real point in favor of the factory option for anyone weighing it.
The ten mega-threads (>100 posts)
| Posts | Variant | Category | Thread |
| 1,259 | ? | Motion | VFA Artifacts on X+Y Straight Edges |
| 419 | factory | Motion | Failed Y-calibration of a new CoreOne |
| 334 | ? | Bed/Adhesion | Core One crash/restart |
| 305 | ? | Motion | Tension pulley broken |
| 206 | ? | Bed/Adhesion | Nozzle cleaning consistently fails with PETG |
| 155 | kit | Motion | HOMING ISSUES |
| 149 | kit | Bed/Adhesion | Skewed XY-Plane (Z Rods, Heatbed) |
| 149 | kit | Motion | Bad Vibrations |
| 108 | ? | Motion | Z axis trouble but only when printing |
| 100 | kit | Upgrade | Different Z lead screw travel between MK4S upgrade screws and Core One kit — 2 mm mismatch |
7 of 10 mega-threads are motion-adjacent. 4 kit, 1 factory, 5 unclassifiable. The VFA artifacts thread alone represents over 254k views — the single biggest gravity well in the Core One support landscape, and it affects both kit and factory populations.
What this means for a prospective buyer
- Motion, gantry, and belt issues are the defining Core One experience regardless of kit or factory. ~30% of troubleshooting threads in both populations. Budget time for tuning belts, resonance, and Z-axis alignment whichever way you buy.
- The MK3/MK4 → Core One upgrade path has its own specific risk profile — 21.4% of kit threads are upgrade-specific. If you're upgrading, read the upgrade-specific threads first.
- Factory-assembled isn't a guarantee of a running printer. Factory units have higher rates of extrusion, first-layer, and print-quality teething issues than kits.
- But factory issues resolve more cleanly — 36% vs 26% effective resolution. Factory failures tend to be single-defect-plus-RMA.
- Kit owners spend most of their frustration on firmware/connectivity after the build is done, not on the build itself. Only ~5% of kit threads are literal assembly errors.
Method notes
- Scraped and parsed all 11,381 posts across 1,094 threads on 2026-04-21.
- Classification is regex-against-content — OP + first 2-5 replies for category/variant, last 3 posts for resolution.
- Earlier version of this analysis used title-only classification and got some things wrong, notably on the factory cluster. This version supersedes it.
- Excluded: General Discussion, How-do-I-print-this, User Mods, Signature Oak (not support-focused).
- Happy to share raw data or the classifier to anyone who wants to re-slice. If you spot miscategorized threads, point them out — content classification is better than title classification but still noisy.
Interesting analysis, thank you! One thought on the issue categories which (counter-intuitively) appear more often in factory-built units than in kits:
Might this simply be due to different levels of experience (on average) between kit builders and buyers of complete units? I.e. print quality issues might not be more common in factory-built printers, but kit builders are more experienced in solving them on their own.
I assume that for the vast majority of kit builders, the Core One is not their first printer, and they have an interest in what happens "under the hood". Among buyers of the factory-built version we probably find a higher percentage of new or casual users of 3D printing.
I thought the same thing, kit buyers might be more experienced and thus less likely to run into print quality issues since they are often caused by user error like: not drying filament, cleaning the sheets or picking the wrong profile.
Disclaimer: I am not defending anyone or any company, just stating some obvious observations.
We have to be careful with A.I. Summaries, because A.I. tries to sound authoritative, but contradicts itself routinely. For one example, take these two phrases that came back from A.I.:
1. "There's no sales-figure denominator, so all percentages below are within-population shares, not per-unit failure rates."
2. Then, in summary, the A.I. says: "both groups report Assembly/Build issues at high rates".
Comment: If you don't know how many were sold, and how many were successful vs. how many posted with a problem, then HOW DO YOU KNOW what a "High Rate" is for these problems? For example: If 10,000 printers were sold, and 1% posted a problem, and half of those (0.5%) were motion/gantry issues, how is that a "High Rate"? See what the risk is? When we read summaries based on incomplete input landscape, the summarization may choose to use words that sound alarming, like, maybe I should not buy this? Rather than a summary based on complete data input that includes total number of units shipped, total number of problems posted to the forum, and total number of problems submitted to support, but not the forum? This type of summary only tells me "Of the people who posted to the forum, instead of contacting support, here is the breakdown of their unique issues. That may or may not match the type and percentages of issue categories that the customer support team gets contacted about. And in addition, a bunch of problems posted to the forum does not give a potential buyer any idea at all if the printer is reliable or not, unless we know the total number of units shipped, vs. the total number/percentage of units with reported problems.
Just food for thought.
Neal
This is very interesting. My build was not without glitches. When doing my start up sequence my printer wouldn’t home. With Prusa help it was determined that I had to square the gantry. After that everything went fine. The only problems I have had were of my own making. The core xy system is different from a bed slinger and I think that’s where folks run into problems. The logic is slightly different what went wrong with the bed slinger isn’t the same on the core xy. There is a learning curve but well worth the effort. Just personal thoughts
To be fair, it's not all about inexperienced users. There were a lot of design issues with the early Core Ones, some still unsolved. Here's my personal shortlist -- I experienced about 2/3 of these myself, and know from the forum that many others have. The remaining 1/3 are from forum discussions, again all confirmed by multiple users as recurring issues:
- Inadequate packaging: Outer box undamaged, but printer has bent frame profiles and shattered polycarbonate panes.
- Door handles come loose spontaneously
- Rubber feet come loose (pre-applied adhesive separates from the rubber!)
- Endless head-banging > bad gantry alignment. Prusa has changed the alignment & belt tensioning instructions repeatedly
- Acoustic noise from the motors, very pronounced in some units > phase stepping calibration eventually released (with firmware 6.4.0?). Required accelerometer is still not included with the printer.
- Pronounced VFAs > after several months Prusa claims revised belt tensioning procedure solves it. Personally I can't confirm that.
- Build instructions leave users with lead screws under lateral strain, locking up the Z drive.
- Magnet in side filament sensor is too large, lever may get stuck once sensor lid is attached.
- Nozzle heater interferes with load cell on some printers. > New wiring harness apparently solves this.
- Heatbed cable cover too high, interferes with the toolhead fan shroud during bed probing and printing in rear left.
- Display cannot operate at full speed in some units. Workaround: Fallback speed in firmware, resulting in sluggish display response.
- Belt tensioner screws seizing (galling), destroying the idler mounts.
- Printer crashing during extended prints, apparently due to charge built up on the belts. Grounding of XY motors helps.
- Different lead screw pitches used in the Z drive, resulting in skewed prints.
- BSOD upon power-up since bootloader 2.5.0, still not fixed after 6 months.
- Input Shaper swaps the axes, fixed in firmware 6.5.3
I dont have any of those problems after my first year of kit C1. Though it was an issue with some screw length or whatever on the cable for the heat bed that i had to fix just after the build, otherwise it could collide.
These were my issues building the Mk4S upgrade kit:
