Belt is touching a zip tie for fan housing
Carl
 Carl
(@carl-2)
I am now assembling the Core One and about half way through. One thing i have noticed is that the top belt teeth are in contact with a zip tie on the plate for the two fans. Even when i put the belt under tension it is still in contact. Is this normal?
Opublikowany : 11/03/2026 12:02 pm
Posted by: @carl-2
No it's not normal. The Core One Assembly Manual has a specific instructions to ensure the zip tie is pushed down enough that it doesn't interfere with the belt. I would remove the fan cover, cut off the zip tie and replace it but ensure it's flatter. You could even remove it entirely.
Opublikowany : 11/03/2026 3:24 pm
Carl
 Carl
(@carl-2)
hyiger,
Thank you for your reply. Just found the comments in the assembly manual...seems to be a common problem. I am going to remove the zip tie entirely: the temp sensor seems pretty secure without the zip tie.
This post was modified 2 months temu by Carl
Opublikowany : 11/03/2026 9:57 pm
