Filter on while printing or after printing?
Torpi
(@torpi)
I have just built the enclosure with the filtration system.
Stupid question, when using smelly filaments, should I use the filter while printing or after the print is done (before opening)? I cannot find any tips on this.
I am quite afraid that while pricing it can generate wind on the model and I only imagine disasters with tall objects.
LED and Filter, I thing it should be good to be able to pilot it on/off from octoprint rather than just a switch.
Thanks,
Torpi
Opublikowany : 18/02/2023 8:23 pm
JMH714
(@jmh714-2)
RE: Filter on while printing or after printing?
From Enclosure page: "The filtration system is useful when you print materials such as PC Blend Carbon Fiber and other materials that produce particles during printing."
That's all I know - Yeah, I bought filter. lol
Opublikowany : 19/02/2023 7:08 am
Torpi
(@torpi)
Well, I plan to test those materials, that’s why I got the enclosure. Nylon too. Not sur le it’s hot enough for tall objects but small gears should be good.
still not sure how to use the filter !! 😉
Opublikowany : 19/02/2023 6:56 pm
TheLivingBubba
(@thelivingbubba)
I have this question as well. I read I believe in a thread here somewhere that they were having success turning the filter on after the print was completed and not getting and odors. I didn't see anything on the Prusa site regarding it. But have yet to try any ABS or ASA
I also wonder that if I need to leave the filter running during the printing, should I do a PID tune for the machine with the filter running, because I'm sure it has some effect.
Opublikowany : 20/02/2023 1:13 am
Morcegolas
(@morcegolas)
Posted by: @torpi
Hello, I received my enclosure yesterday, I don’t know about the filter but I think it must be on while printing, and some minutes after the print finish.
Regarding turning on/off filter and LEDs with octoprint, maybe with enclosure plugin did you found something? I really need this too, I was using another LEDs that I turn on/off with my smart home application but now I can’t do it anymore.
Opublikowany : 23/02/2023 5:00 pm
Torpi
(@torpi)
Well, you would have to hack the PCB to be able to pilot it since there is no connection to the printer nor octoprint. Like having a GPIO that you connect to the actual switch.
Opublikowany : 23/02/2023 6:24 pm
Jojo0526
(@jojo0526)
Hello,
I juste mount the enclosure and start printing with the filter on but the temperature of the bed drops by more than 10°C so the printer set a error...
Did you have already encounter this problem ? How to fix that ?
 Thanks for your help
Opublikowany : 28/03/2023 12:34 pm
