Am i to stupid to Print PETG?!!
maxluzi
(@maxluzi)
Sadly, there isn't a German CORE ONE L forum, so I will try my best in English.
First of all, I’m not new to 3D printing. My MK3S worked so amazingly well that I might be a bit spoiled by it; I never had issues with PLA or PETG on that machine.
I had a rough start with the Core One L because I didn’t mount the 0.6mm nozzle perfectly, which caused a minor crash. Luckily, no permanent damage was done. After that, I printed a few Benchys and Cali-Flowers in PLA, and everything was fine and accurate.
The printer is supposed to run daily for parts and jigs in our woodshop. I bought the Core One specifically because I want to design in Fusion and print parts quickly. However, it seems my Core One isn't printing as well out of the box as I expected. I admit I’m a little frustrated; I don’t want to spend time "tinkering"—I want to work and provide my employees with the parts they need just-in-time.
After some issues with large ASA parts (which were mostly geometry-related), my PETG prints are now failing as well. I’m using Prusament PETG right out of the box to print feet for a steel table. Here is what I’ve tried:
1st Attempt: 0.6mm nozzle, 0.32mm Structural profile (255/85°C), 4 perimeters, 6 bottom/4 top layers, 20% infill. Result: Huge layer shift at the top. No Foto
2nd Attempt: 0.6mm nozzle, 0.32mm Balanced profile (255/85°C), 2 perimeters, 4 bottom/5 top layers, 100% infill. Result: Nope
3rd Attempt: 0.6mm nozzle, 0.4mm Structural profile (265/85°C), 2 perimeters, 100% infill, reduced volumetric flow (10). Result: Also poor, canceled
4th Attempt: 0.6mm nozzle, 0.3mm Structural profile (265/85°C), 2 perimeters, 100% infill, reduced volumetric flow (10). Nope
5th Attempt: 0.6mm nozzle, 0.3mm Structural profile (265/85°C), 9 perimeters, 15% infill, reduced volumetric flow (10). Ok, but not
6th Attempt: (Tried standard parameters with a 0.4mm nozzle to rule out user error): 0.2mm Structural profile (255/85°C), 2 perimeters, 15% infill. Result: Severe layer shifting, canceled
Should I contact support directly? I invested a lot of money into a Prusa specifically because I need a reliable workhorse for my business. Any help would be appreciated.
PS: Actually it prints a perfect PLA print....
Best Answer by Ruebarb:
I also have a Mk3S that still prints flawlessly. The C1L, the print quality is better, but takes alot of tuning.
Z offset adjustment to ensure bed adhesion. -0.02. Peform a live z test, just like the Mk3
Do a temp tower
Disable chamber fans, warping, bed lifting. In filament set chamber nomial to 0. will stop the chamber fan from running.
Slower print speed, default profiles way too fast.
If you are using the HF, use a standard nozzle. I find the HF to be a gimmic. Quality vs speed. Your call.
Default PETG profile is crap.
Don't carry anything over from the Mk3S
See the PETG & Print Settings in the included zip
Publié : 05/02/2026 7:58 pm
1 personnes ont aimé
Ruebarb
(@ruebarb)
RE: Am i to stupid to Print PETG?!!
Do a temp tower
Core One L MMU3, MK3S
Publié : 06/02/2026 3:35 pm
Posted by: @maxluzi
This actually might be your problem. Try drying the filament for 8hrs at 60° before printing. I never assume that filament is dry after removing it from even a factory vacuum sealed bag.
Publié : 06/02/2026 8:34 pm
maxluzi
(@maxluzi)
Problem solved! I have an amazing print quality with the same filament now.
Added your printer and your profile and it just works sooooo good. Now I have the quality that I've been expecting.
I'm glad it's a software problem. Prusa SHOULD replace their profile with yours!
I would really appreciate, if you can post a kind of a change log for your printer and filament settings so I don't need to compare and figure out...
Thank you mate, kinda love you 🤣
Publié : 07/02/2026 7:27 pm
Posted by: @maxluzi
As I've mentioned in other posts, the Prusa profiles are generic and are really only good for average prints of generic objects. They are just a starting point. If you want, clean functional prints then you need to calibrate your filament and, as @Ruebarb pointed out, stay away from HF nozzles for functional prints. I highly recommend the Diamondback nozzles.
Publié : 07/02/2026 8:00 pm
Ruebarb
(@ruebarb)
Glad to help. It is dissapointing Prusa doesn't make anyone more successful. You would figure using thier own filament on thier own printer would be easy.
If you added the actual printer profile, I have some custom G code for a nozzle wipe and to open and close vent based on filament min temp. It will always close the vent at the end.
Publié : 07/02/2026 9:24 pm
Posted by: @ruebarb
It really isn't that easy though. For example the countless posts I saw here and on Reddit where users were blaming the printer for wet filament, a dirty build plate or using the wrong nozzle.
The Prusa profiles are a "best guess" and can never be anything more than that. Just changing the print sheet is enough to invalidate a Prusa profile for Prusament in some cases.
Publié : 07/02/2026 9:36 pm
mnentwig
(@mnentwig)
It would be interesting to find out what exactly is the root cause. You've rattled the box, the problem went away but it may come back.
With few exceptions, I print only budget material and found the "generic" stock presets are spot-on. A little bit of tweaking here and there to correct for actual shrinkage (XY and Z multiplier), extrusion multiplier for fine tuning, possibly raise temperature but nothing that should cause functional failure as in your pictures. It's not that sensitive - or if it is, this points to some deeper, underlying issue.
This statement holds for several 2nd-tier brands of ASA, ABS, PETG and unicorn-pink PLA which I only touch with rubber gloves.
Publié : 07/02/2026 9:41 pm
maxluzi
(@maxluzi)
same for me. i´ve been printing with my mk3s (with enclosure) a few spools of cheap pla and petg perfect with the generic profile.
i also printet really a LOT ASA, PLA and PETG with my mk3s almost without any issues. It was running for about 4 years until i bougth the COL.
i have never needed to change some fillament seetings, except first layer temp or something like this. so there was just no need to get any deeper in into this.
now with the new printer i should make a calibration for every original prusament? c´mon. this was far away from a little tuning. the prints went from worse to good wit  your petg profile..
if you @ruebarb could tell us the changes you made in the filamet it will save me or us some study. i want to understand what was wrong...
Ce message a été modifié il y a 3 months par maxluzi
Publié : 07/02/2026 9:59 pm
_KaszpiR_
(@_kaszpir_)
you can compare it on your own in the PrusaSlicer - enable expert mode and then on each tab click Compare (the first on the right)
Looking at it I see there aren't that many differences, maybe the original profiles were corrupted?
Publié : 07/02/2026 10:25 pm
Ruebarb
(@ruebarb)
The Print Settings, those adjustments are just my own, some from previous experience with the MK3S. I started with the Structual and then adjusted from there. Speed is not your friend for quality prints.
The Filament settings, I had a decent profile of my own based on the default PETG , but was still not happy. Since Prusa makes parts out of their own PETG for thier printers,  knew it could be done, but the default profile wasn't it.  I grabbed one of the Prusa Mk3 files from thier Core one + printable parts files and looked it, found a bunch of changes that are not in the included default Prusa profile. Lots of testing after that, problem solving for bed adhesion, warping issue, chamber fans.......
It is just a combination of all things, print settings, extruder tuning, z offset, filament settings, temp tower, bridge test, stringing test, elephant foots test, chamber fans, print sheet.  Get it all right and you get a good repeatable result.
Each time I start a new filament, I go through all the steps again. The better base profiles I build,  the quicker it becomes to add more of that type. I may spend an entire day + just testing a filamanet, sometimes much longer, like the PETG.
Posted by: @maxluzi
Publié : 08/02/2026 1:52 am
alphasigma
(@alphasigma)
Throwing in my experience printing with PCTG:
- Core One L
- textured sheet
- Prusa ObXidian 0.4 nozzle
- PCTG from nobufil
- Creality SpacePi X4 dryer and I am printing out of the dryer and it is switched on during the print - drying modus or "Auto"-modus with 20% threshold
- starting preset was the "Spectrum PCTG" preset in Prusa Slicer
- final tuned nozzle temperature: 256 °C
- final bed temperature: 90 °C (from the beginning)
- fan speed changed to nobufil settings - 30% up to 50%
- print mostly with "0,15 layer Balanced" (one of the presets in easyprint)
- larger parts "0,15 layer Structured (for a perfect surface and better layer bonding)
- first print was the Benchy from Prusa on Printables (the Benchy on the USB stick ist heavely optimized for PLA with factory out Standard HF nozzle)
- observed the result when the first layer was printed
- adjusted nozzle temperature
- print finished flawless
- never touched "z-axis" settings
- never printed a calibration model
My conlusions/recommendations:
- start with a preset or the closest preset when not using the preset filament
- observe the first layer(s)
- tune settings during print
- dry, dry, dry, dry your filament or keep it dry at least
(- printing policy when using a filament the first time: First print is the Benchy for tuning 🙂 )
Core One L
Publié : 12/02/2026 1:29 pm
Lakwell
(@lakwell)
Hi
I am jumping in as I have printing issue using prusament PETG too and spend all the morning to test different set-up, but none was good.
I did several search and found this post.
I know that this discussion in the Core L forum but I read that @ruebarb also have a MK3S...and are the profiles sent above are also for the MK3S+ ?
As @maxluzi, I mostly print ASA with no issues, as well as PLA, TPU.
I have issue with PETG only, well dry, printed or I will rather say trying to print PETG in a Prusa Enclosure heated at 30/35°C.
Despite having check my bed leveling which seems to be quite good, with a Live Z Offset at -0.38 now , I am still fighting with the 1st layer and even more from the start of the small oultine not sticking/adhering to the steelsheet from and for the very first point, and I don't know what I missed.
Happy to get your insights or suggestions 😉
Printer : MK3S+
Nozzle 0.4
Print settings : back to the basic ones in system presets : 0.20mm Quality (and try speed too first, also tried the 0.30mm draft).
steelsheet : Textured
filament Prusament PETG
mainly took the set from The Perfect Prusa i3 PETG Settings
Nozzle temp : 230 then 240
heatbed temp : 85 then 90
cooling fan speed min 30% max 50%  Auto cooling : ticked ON , Keep always FAN ON : unticked
Bridges fan speed 50%
disable fan for the first 3 layers
full fan speed at layer 4
brim width 5mm
Infill 15%
travelling speed : 130mm/s
Retractation speed 40mm/s
Retraction length 5mm
1st Layer speed : 20mm/s
speed for print moves in mm/s:
   Perimeters : 45
   small perimeters : 25
   external perimeters : 25
   infill : 80
   solid infill 80
   top solid infill : 40
Why do I miss ? 😭
Ce message a été modifié il y a 1 month 2 fois par Lakwell
Publié : 03/04/2026 11:05 am
How are you cleaning your print sheet?  It must be thoroughly clean for the first layer to stick properly, some new textured sheets work better if the live-Z value is dialed down slightly at the start of a print; after a little wear the need goes away.
Publié : 03/04/2026 12:41 pm
Lakwell
(@lakwell)
Hi
I cleaned it with a dish washer, from the kitchen 😉
After posting here, I reminf about the Prusa discord. I also put my message here and a member reply me.
I needed to change Retract length to 1mm (not 5 like you write) as I got direct drive
increase the temp to try 250-80 for the first layer and then 240-80, too high and stringing.
so I moved down to 230, then 225 to finally stay now at 223, with a Live Z offset at 0.385, after having try -0.38 and -0.39...
Not yet perfect but at least I am printing since 30 min with no issues, hopefully
Publié : 03/04/2026 1:16 pm
Ruebarb
(@ruebarb)
I do not have profile for Prusa PETG for the Mk3S, same as plus. I tried it when I first started and had alot of adhesion issues.
This profile should get you close.
Here is the profile for Sunlu PETG, Prusa prints higher, so you may need to adjust the temp. Print a temp tower.
It took me a long time to get PETG perfect, still sticks more reliable on the MK3S then the C1L.
I also have a Lack enclosure, that helps. PETG likes staying warm with no draft.
The Live z is critical to PETG on the MK3. You need to get this perfect. https://forum.prusa3d.com/forum/postid/786532/
Publié : 03/04/2026 1:31 pm
Lakwell
(@lakwell)
Many thanks 😉
Publié : 03/04/2026 2:52 pm
