Looking for a more powerful heater.
beegmouse
(@beegmouse)
I'm running 0.4mm HF nozzles, and I do a lot of draft quality parts for production jigs where visual quality is not critical at all.
I used to have an MK3S with0.8mm Revo and a 40W heater, and that thing could eat through a reel at 0.4mm layer height with fantastic accuracy once arachne was implemented.
The Prusa Hot End seems very bad at getting the heat into the filament. The 0.4mm nozzle is at 90% duty cycle on 0.28 layer height, and it's not even particularly quick. I don't see how the heater could keep up with an 0.6mm HF.
I'd love to get one of my nozzles transitioned over to a 60W revo with an 0.8mm High flow. Has anyone ever done this, and what are the blockages?
There were issues with the thermal modelling on the MK3 which you had disable to turn off. Is there enough power availaible to drive a 60W heater on the printer?
A revo heater and nozzle are more compact than the prusa solution, so I'm sure it could fit, but the cold side would need re-modelling to fit. Has anyone ever done this?
At this point, I'm actually tempted to pick up a used MK3S to do this, as It looks to be about 4x faster than the current XL setup. I just have large parts it can't achieve.
Veröffentlicht : 13/03/2025 9:57 am
Neal3d
(@neal3d)
RE: Looking for a more powerful heater.
@beegmouse I agree I'd like to see a Hight temp heater that can do ~330-350C. I'd love to try some PPS-CF Filament in the XL. Maybe a  Mod replacing some of the 3D printed parts that like to creep in the XL. Motor Mounts, Belt Tensioners etc.
Veröffentlicht : 12/04/2025 2:04 pm
DoctorWTF
(@doctorwtf)
I'd also be interested in higher temperatures - my main reason for wanting a new 3D printer is to be able to work with carbon-infused polycarbonate, for which 290C is just barely adequate.
Veröffentlicht : 04/05/2025 1:10 pm
beegmouse
(@beegmouse)
I think you guys mis understood.
I don't want hotter, I want more power.
If you want hotter, you'd need more than just a new Hot end, every PETG part in the printer would need swapping out. The Enclosure would need to be heated and insulated.
Posted by: @doctorwtf
I am Using PC-CF filament on the XL and it handles it perfectly.
Veröffentlicht : 07/07/2025 12:31 pm
