Printing MultiColor Flush Text
gkas
 gkas
(@gkas)
I've been playing around with the PrusaSlicer TEXT (T) option, since I don't have my printer yet. I would like to create MultiColor text, FLUSH with the surface, not embossed or debossed.  So far I can't even get flush test. Should I create embossed text, then lower it's height. I tried 0.0mm and 0.1m, but the slicer would net accept them. It seems like flush text with color would be nice for tags, boxes, etc.
tnx...
Opublikowany : 10/07/2023 5:36 am
jkavalik
(@jkavalik)
You just need to change the type/operation to "modifier". Either in the Emboss dialog for the Text or by right-click->change type. Then you can set a separate extruder for the text and it will be flush. Only you need to have some depth to it, to actually affect a big enough part of the main model to print, depth 0 would mean that it won't do anything.
And don't let yourself be fooled by the preview of the text being above the surface all the time 🙂
Opublikowany : 10/07/2023 6:57 am
2 ludzie polubili
While you're waiting try multicolour printing with your Mk3 - the underying principles are the same ...  then you'll be ready when it arrives.
https://forum.prusa3d.com/forum/prusaslicer/manual-multicolor/
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-how-do-i-print-this-printing-help/acting-as-my-own-mmu
Opublikowany : 10/07/2023 4:37 pm
burtronix
(@burtronix)
RE: Printing MultiColor Flush Text
I plan on doing my flush text in the CAD software, so I'll have a different mesh body for each character.
Whatever you find to do with your hands, do with all your might!
Opublikowany : 25/07/2023 6:12 pm
Group the text together as a multipart object - then it's much easier to place.
Opublikowany : 25/07/2023 8:04 pm
1 ludzie polubili
Rufus
(@rufus)
Hi, can you be a little more specific on this? I have a piece that I imported as a STP and thought it could be split but that option is greyed out. How do you convert it to a multipart if the letters where created in a cad program??
Opublikowany : 29/10/2023 7:01 pm
Attached is a zip containing two files - rufus1.stl and rufus2.stl - optimised for 0.2mm layers.
Import both at the same time into any multicolour printer profile - accept them as parts of the same object and slice.
Opublikowany : 29/10/2023 8:00 pm
