The printer produces a buzzing / vibrating sound, similar to a beard trimmer or electric razor, during axis movement.
Hey everyone,
My Prusa XL and I’ve noticed a kind of buzzing / vibrating sound during movement — the best way I can describe it is like a beard trimmer / electric razor 😅
It happens mostly during travel moves or at certain speeds. Other than that, everything seems perfectly fine.
However, I actually stopped the print early because I was worried it might lead to bigger issues if I continue printing.
So before I keep using it, I wanted to ask:
Has anyone experienced this kind of sound on the XL? Is this normal (like motor/belt resonance), or something I should fix first? Should I check belt tension or lubrication, or just continue printing?
I can upload a video with sound if that helps.
Thanks a lot 🙌
Posted : 24/03/2026 7:44 pm
