Print skew
User64X
(@user64x)
Print skew
I've noticed there's several millimeters of skew on the print bed.  Any suggestions on how to correct this print skew?
Postato : 02/09/2024 7:30 am
Racemade3D
(@racemade3d)
Utenti
Following...
The Califlower (Youtube; CNC Kitchen) is a good method to identify skew.
But i have no idea how to put the code into prusa.
Questo post è stato modificato 2 years fa da Racemade3D
Postato : 09/09/2024 4:12 pm
ntdesign
(@ntdesign)
RE: Print skew
Assuming your extrusions are all perpendicular and your x carriage not bent, the most likely reason is different belt tension. Try to check/correct that before you go on a red herring hunt.
Postato : 10/09/2024 1:17 pm
