Following...
The Califlower (Youtube; CNC Kitchen) is a good method to identify skew.
But i have no idea how to put the code into prusa.
Ce message a été modifié il y a 2 years par Racemade3D
Publié : 09/09/2024 4:12 pm
RE: Print skew
Assuming your extrusions are all perpendicular and your x carriage not bent, the most likely reason is different belt tension. Try to check/correct that before you go on a red herring hunt.
Publié : 10/09/2024 1:17 pm
