Octoprint setup
allanonmage
(@allanonmage)
Octoprint setup
I added 5 toolheads to the printer profile, in addition to the adjustments on this article. I just sent my first print job to the XL over Octoprint, and it's heating toolhead 1 to 170 and just sitting there for almost 10 mins now. I saw on github there's a heat up time period that can't be avoided? This is my 2nd print on this printer, so I'm not that familiar with it yet. Is this normal, or is it broken?
https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/octoprint-issue/
https://github.com/mlbreit/OctoPrint-PrusaXL/
I use Octoprint for all my printers. That changes my point of reference substantially.I have a couple Is MK 3's, an XL on the way, a fleet of Ender 3v2s, a couple Lulzbot Taz 6's, a CR30 and…
Napsal : 04/01/2026 4:08 am
allanonmage
(@allanonmage)
RE: Octoprint setup
I had loaded some filament, and it was stuck in the loading and unloading loop and then timed out, which locked the printer out. Also turns out the filament sensor on one of the toolheads needed to be recalibrated since I had moved it around.
Napsal : 04/01/2026 5:02 am
1 lidem se líbí
Zwirbel
(@zwirbel)
RE: Octoprint setup
Yes, there is an "absorbing heat" step with every print, but unfortunately, OctoPrint can't show this. Just wait, it will continue.
Napsal : 05/01/2026 9:56 am
