Manuals on greasing, ... maintenance
ludodg
(@ludodg)
I only found this page on greasing the coupler pins:
https://help.prusa3d.com/guide/how-to-lubricate-the-coupler-pins-on-original-prusa-xl-multi-tool_636777?fbclid=IwAR3gNXNHj6csyk_Eq4eAAHoz29nZmYoRmRQ5PFzyEt_T2DQK8e4yhuzVyxQ
But is or are there also other manuals on how to grease other parts, rods, on how to check belt-tension...
I'm almost sure there must be but I seem to miss these. Any hint someone?
Opublikowany : 08/02/2024 1:42 am
RE: Manuals on greasing, ... maintenance
https://help.prusa3d.com/article/regular-printer-maintenance-xl_401237
Opublikowany : 08/02/2024 5:18 am
blauzahn
(@blauzahn)
It looks like being partially copied from the MK3. See paragraph about the belt.
Opublikowany : 08/02/2024 6:09 am
ludodg
(@ludodg)
THX
I was clearly searching in the wrong sections
Opublikowany : 08/02/2024 9:15 am
ludodg
(@ludodg)
I find it strange that they mention acetone should not be used on the textured sheet.
For the MK3-machines it was actually adviced to do a acetone-swipe every month or two, on the textured sheet, if I recall well.
Opublikowany : 08/02/2024 9:17 am
