Is it possible to add an SD card for onboard files storage - I get errors when i print a large file from prusa connect
Does anyone know if it is possible to add storage via a microSD card for storage. Seems crazy that there is no onboard storage for print files.
I tried printing a large file via Prusa Connect and i got an error stating that it could not transfer info fast enough. I think it would be much better if the file was downloaded to the printer's "internal" storage.
I dont like the idea of having to use a usb key to transfer files...
Cheers,
Hem
Napsal : 13/05/2024 10:48 pm
RE: Is it possible to add an SD card for onboard files storage - I get errors when i print a large file from prusa connect
Just keep the usb key attached to the printer, the files will be uploaded there. At least when using PrusaLink, not sure about PrusaConnect
Napsal : 14/05/2024 9:11 pm
