First tool-head used only for prime line? Prusa XL 5TH
JC
 JC
(@jc-3)
I am slicing a multi TH (Tool Head) print and even though I only use TH3 and TH4 on the print, it still bed levels and primes TH1.  I can't figure out why. This is annoying as it gets drabs from TH1 on the print.   Is there a slicer setting I am not using correctly?  Appreciate your thoughts.
(I could switch out filament and potentially nozzles to always use TH1 in a print, but that is inconvenient...)
Thanks!
(Folder w/ slicer project attached...)
https://drive.google.com/drive/folders/1JBdUbJvVMYUq6Ed-GGit7vvby466ytJ0?usp=sharing
Best Answer by BaconFase:
It's because you're using a modified Printer Profile for a 1T. I switched it to a default 5T profile and the tool1 purge isn't there.
Respondido : 11/12/2023 1:54 am
EvilleBill
(@evillebill)
RE: First tool-head used only for prime line? Prusa XL 5TH
Agreed, I find this nonsensical and annoying.
But is the fault in the slicer or the firmware, or both?
Respondido : 11/12/2023 4:31 am
BaconFase
(@baconfase)
Respondido : 11/12/2023 9:17 am
JC
 JC
(@jc-3)
Thanks,
That did it!
Respondido : 13/12/2023 4:07 pm
GUTSP
(@gutsp)
Miembro
How do i add a "Standard" 5-tool profile?
Respondido : 23/02/2024 8:10 am
tg73
 tg73
(@tg73)
Miembro
See the docs here:
https://help.prusa3d.com/article/configuration-wizard_1754
Respondido : 23/02/2024 1:20 pm
