First tool-head used only for prime line? Prusa XL 5TH
I am slicing a multi TH (Tool Head) print and even though I only use TH3 and TH4 on the print, it still bed levels and primes TH1. I can't figure out why. This is annoying as it gets drabs from TH1 on the print. Is there a slicer setting I am not using correctly? Appreciate your thoughts.
(I could switch out filament and potentially nozzles to always use TH1 in a print, but that is inconvenient...)
Thanks!
(Folder w/ slicer project attached...)
https://drive.google.com/drive/folders/1JBdUbJvVMYUq6Ed-GGit7vvby466ytJ0?usp=sharing
Best Answer by BaconFase:
It's because you're using a modified Printer Profile for a 1T. I switched it to a default 5T profile and the tool1 purge isn't there.
RE: First tool-head used only for prime line? Prusa XL 5TH
Agreed, I find this nonsensical and annoying.
But is the fault in the slicer or the firmware, or both?
XL-5T, MK3S MMU3 || GUIDE: How to print with multiple-nozzlesizes do read updated replies || PrusaSlicer Fork with some flags removed || How Feasible is Printing PETG for PLA supports on XL very
Thanks,
That did it!
How do i add a "Standard" 5-tool profile?
See the docs here:
