WiFi configuration file
flounder
(@flounder)
You have still not fixed the problem where I cannot write the WiFi configuration file because Windows thinks the media is not removable.  As I pointed out, you could warn me of this situation but it is always my choice as to where I write the file, and if I say "go ahead and write the file" then you must write the file where I tell you.  No option on your part.  I lose a significant advantage in using the printer by not being able to access a feature I paid for.  Just fix the code, OK?
Opublikowany : 01/08/2024 6:16 am
JP Guitars
(@jp-guitars)
RE: WiFi configuration file
Posted by: @flounder
Sounds like a Windows problem to me and nothing to do with Prusa
Opublikowany : 01/08/2024 7:46 am
1 ludzie polubili
