Prusa Slicer Bug
flounder
(@flounder)
Prusa Slicer Bug
When are you going to remove the code that prevents me from writing the network configuration file to the flash  drive?  It tells me the flash drive is not a removable device.  While it is ok to warn me about this, you must give the option of writing it anyway.  I feel I have been cheated because I cannot make a wireless connection.  You programmer is entitled to warn me, but not forbid me, from writing to whatever device I choose to write it to.
Postato : 11/11/2024 1:05 am
RE: Prusa Slicer Bug
This is a user to user forum.  The devs rarely come here and they don't answer bug reports via here.
IF you want to report an issue then you have to raise it at the appropriate prusa github repository.  For example the Prusa Slicer one is here https://github.com/prusa3d/PrusaSlicer/issues
The Prusa XL one is here https://github.com/prusa3d/Prusa-Firmware-Buddy
Prusa Link - https://github.com/prusa3d/Prusa-Link/issues
Prusa Connect - https://github.com/prusa3d/Prusa-Connect-SDK-Printer/issues
Please choose the the appropriate one and follow the submission guidelines when opening a new one.  Also before opening one please do a search of existing issues, both open and closed to see if one already exists.
Posting here will not get you any official action at all.  Good Luck.
Postato : 11/11/2024 1:15 am
JP Guitars
(@jp-guitars)
If slicer will not write the credentials then you can write them yourself using any text editor,  see kb article below
https://help.prusa3d.com/guide/wi-fi-and-prusalink-setup-mk4-mk3-9-mk3-5-xl-mini_413293#414870
Postato : 11/11/2024 7:56 am
