print fan rpm test failing
Zachary Turner
(@zachary-turner)
I just finished assembling the XL multi-tool.  Immediatley after starting the self tests, the print fan rpm test fails with no diagnostic information.  I can see both fans spinning on the 2 tool changers.  I'm new to all this so I'm not sure what I should be looking at.  I'm pretty sure I assembled everything correctly.  My firmware is 6.2.6.
Does anyone have any suggestions how to resolve this?
This topic was modified 6 months temu by Zachary Turner
Opublikowany : 16/11/2025 6:50 am
walsercl
(@walsercl)
RE: print fan rpm test failing
This is a common issue, i executed the test on my XL yesterday and all five print fan rpm tests failed.
After digging a bit in the internet, i've noticed that prusa recommends to remove the fan shrouds during the test and add it again afterwards.
https://help.prusa3d.com/article/selftest-failed-xl-multi-tool_686941
Here is a good video example of it, this fixed the issue for me and the test finished successful
https://www.youtube.com/shorts/Lfm1C1aRYNw
Hope this helps, best regards
Opublikowany : 16/11/2025 2:22 pm
1 ludzie polubili
Richard Reed
(@richard-reed)
I had exactly the same issue this weekend after installing a new dwarf board. I found if you switch the fan type from black to silver the hotend fan will pass. I then tested with out a shroud and found that the print fan will pass that way, but I read of someone else using a hoover to help increase the fan speeds so I put that at the nozzle and it worked.
Hope that helps. I eamiled tech support cause it seems the support team are off this weekend, (maybe getting ready for next weeks reveals)
All the best
Opublikowany : 16/11/2025 4:37 pm
Hammbone
(@hammbone)
Just wanted to confirm, what Walsercl suggested worked for me as well. I recently built the 5TH. It passed everything on startup, but after the recent update in firmware (6.4.0+11974), it wanted me to run the tests again. The print fan test failed on TH's 1,2,3, & 5. Took all the shrouds off and ran it again. All passed.
Thanks for the fix!
Opublikowany : 01/12/2025 10:31 pm
1 ludzie polubili
bgreen4748
(@bgreen4748)
Hello All:
Just finished assembly on XL 5 Head. First Test - Print Fan RPM Failure - first time, just head 1 and 4. 2nd time: All fail but 3. Third time: All Fail.
Removed Fan Shrouds and still Fails.. Brand new firmware upgrade: 6.2.6
Wow, just wow. Really disappointed
Opublikowany : 31/12/2025 4:29 am
wm_hdly
(@wm_hdly)
Same here. I removed all the shrouds and most fans continue to fail the test. Every test may have a different result of which fan passed, but most fail every test.
Opublikowany : 14/01/2026 12:03 am
Zwirbel
(@zwirbel)
You should get in contact with Prusa support (live chat). I had to repeat the test about 10 times and (magically, without changing anything), all fans passed.
Opublikowany : 14/01/2026 9:28 am
wm_hdly
(@wm_hdly)
It's on my list for today. I've tested no less than 30 times with different results >85% of the time. The most consistent fan test is the single extruder that was not part of the upgrade kit. It has the black fan. The others are from the upgrade kit (5 extruder kit) with the silver fans. They will randomly pass or fail in any sort of order. Sadly, they've all passed at one point or another. The closest I got was 4 of 5 fans passing, but that was one time; otherwise, I've had no more than 2 or 3 fans pass for any given test. I've removed the shrouds and ensured there's nothing blocking. I've adjusted the tightness of the screws holding the fan housings in place. I'll test a few more times this morning (mostly because I hate not having a completed calibration test), but I suspect I'm just going to have to go forward without finishing fan calibration.
Opublikowany : 14/01/2026 11:21 am
MartinWesselink
(@martinwesselink)
Kijk even welke kleur ventilatoren je hebt, waarschijnlijk zilver.
Dan moet je de configuratie even bijstellen.
Opublikowany : 14/01/2026 12:58 pm
