print just stops
bapski
(@bapski)
print just stops
i've had this happening more often randomly now where while the Prusa XL is printing, it'll just stop. No error codes, a toolhead is engaged and just stops on top of the print.
what i have done is do a PANIC STOP (power off) and turn the power back on and the print just resumes like nothing.
what is going on? i've read a couple of threads and posts about this but nothing i've seen that is considered a remedy. thanks for your help.
MY MODELS AT PRINTABLES
Publié : 03/02/2025 2:12 pm
1 personnes ont aimé
bapski
(@bapski)
RE: print just stops
im also on the current firmware 6.2.0
Publié : 03/02/2025 2:22 pm
Michael
(@michael-2)
I had similar problems and i think the cause was a usb drive.
Publié : 04/02/2025 8:15 pm
bapski
(@bapski)
i ditched the usb drive that came with the XL and changed it to this:
Sandisk 32gb low profile
What did you get for yours?
Publié : 19/02/2025 2:45 pm
Flowerpool
(@flowerpool)
This happens to me too on 6.2.1. I am still using the Prusa supplied flash drive. Has the new drive helped?
Have you found it helps to turn off prusa connect?
Publié : 22/02/2025 3:31 am
Michael
(@michael-2)
RE: print just stopsi had the lllll I had the problem on a couple of different USB drives
I had the problem on a Prusa and also a Samsung USB . I fixed it by doing a format in windows and unticking the quick format option. The format took 20 to 30 minutes and it fixed the problem.
Publié : 22/02/2025 5:34 am
liska
(@liska)
Membre
Same here. I tried different USB drives, format them, but printer just stoping without any error message. 🙁
Publié : 16/03/2025 12:44 pm
Eric M
(@eric-m)
Membre
Since the update everything has been going wrong with my XL 5T. Nozzle temps wild, printer stops and crashes for no reason, even more filament jams and clogs than before which is hard to believe. Failed prints. etc..
Publié : 01/04/2025 7:22 pm
