SL1S halts during initialization post OTA firmware upgrade to 1.7.0
[Resuelto] SL1S halts during initialization post OTA firmware upgrade to 1.7.0
staticlinerich
(@staticlinerich)
4 day old printer. Firmware was at 1.6.6. I wanted to try the FEB cleaning feature and a few other things. I upgraded the firmware to 1.7.0 utilizing the option on the printer control panel. Printer reboots and is stuck at initializing and the front power button is slowly blinking yellow. Been snooping around the Prusa help articles but cannot find any procedure to reset the print. The USB key method assumes you are already booted into the firmware and can access the menu. An ideas and thanks.
Respondido : 04/05/2022 5:58 am
staticlinerich
(@staticlinerich)
If you have a hung up FW update or have installed 1.7rc4 like I did and get a non response printer, do the following. It worked for me anyway.
1. Download the latest stable firmware.
2. Extract .raucb file from the archive and save it to the USB flash drive with name: sla-emergency-update.raucb The name has to be exact.
3. Turn off the printer.
4. Plug in the USB drive.
5. Turn on the printer. The emergency update does not show anything on the touchscreen. Update process runs completely in the background. After installation is done, the printer reboots. So wait for the touchscreen to turn off the backlight.
6. and unplug the USB drive.
7. Power on the Printer It should boot  into a newly flashed FW
Esta publicación ha sido modificada el hace 4 years 2 veces por staticlinerich
Respondido : 04/05/2022 6:17 pm
1 les gusta
primefac
(@primefac)
RE: SL1S halts during initialization post OTA firmware upgrade to 1.7.0
Just wanted to leave thanks for this, my printer bricked on its latest firmware update and this helped me get it un-stuck.
One thing to mention is that I had to remove everything except the .raucb file from the USB for this method to work (i.e. it was the only thing on there).
Respondido : 16/05/2022 10:02 am
Piranha
(@piranha)
Didn't work for me unfortunately 🙁
Respondido : 18/05/2022 9:05 pm
staticlinerich
(@staticlinerich)
Try this. It also worked for me. The developers asked for logs from my printer, which I submitted. Hope it helps figure out what's going on. This is exactly what I was told to do.
switch the printer on and off 3 times: press the power button, wait 3-5 seconds, press again to turn off, repeat 3 times in a row, the reboot after, the printer should roll back to the firmware previously installed version,
This did work and is my go to method of getting back to 1.6.6. I'm still trying to get 1.7 on this printer 😊
Respondido : 18/05/2022 10:39 pm
Piranha
(@piranha)
By power button I assume you mean the one at the back of the printer?
Respondido : 18/05/2022 10:40 pm
staticlinerich
(@staticlinerich)
No, leave that one on. I'm talking about the power button on front.
Respondido : 18/05/2022 10:45 pm
primefac
(@primefac)
To summarise what I said in the other thread about this subject, officially it's a bug in the beta, which will be fixed prior to the official version release. In other words, we're stuck with 1.6.6 for now.
Respondido : 20/05/2022 10:15 am
