"LOading" USB files
2regburgessearthlink.net
(@2regburgessearthlink-net)
"LOading" USB files
A general question about the loading of files from a USB stick.
Is the  file loaded "all at once" or is it accessed layer by layer as the print progresses ?
I ask because I started a 3 hour print yesterday and went off to edit a different model - so an hour later I wanted to put the sliced model on the same USB stick.    So, can I remove the USB sick as soon as the print starts ?
Sure, I have more than one USB stick, but I would like to keep this set of prints all together.
Anyone know ?
Respondido : 02/07/2022 3:56 pm
Today I Made
(@today-i-made)
Miembro
RE: "LOading" USB files
Hi!
To answer you question, despite it being years later... but if someone else sees this while searching and wondering, I quote from elsewhere in the help.prusa3d.com:
"The printer will copy the project to its internal memory during printing."
This means you should be fine removing the USB stick during a print. However... Do you really need to copy the file onto the stick mid-print? I would say there's always a risk unplugging any device mid operation, and you probably can wait that two hours for the print to finish, right?
Respondido : 17/12/2025 12:29 am
