CW1 Tank Proximity Sensor Failure
In the manual it talks about testing the Proximity Sensor by placing your finger over it to test that it recognizes the tank is in place or not. My problem is the reverse .. it does not recognize that the tank has been removed. The sensor is clean and I went as far as shining a flashlight directly into the sensor .. no luck .. it refuses to switch to curing/drying. I am pretty sure that I will need to contact tech support .. but since I was looking around the forum for solutions to the problem thought I would post this up .. see if anyone else has had the same issue.
Postato : 01/11/2020 7:34 pm
