CW1 + Formlabs
AM
 AM
(@am)
CW1 + Formlabs
does anyone have a experience with using CW1 + formlabs resin?
AM
Opublikowany : 28/02/2021 3:41 pm
gnat
 gnat
(@gnat)
RE: CW1 + Formlabs
No, but FormLabs says the FormCure uses 405nm UV so I would expect that the CW1 should be up to the task.
MMU tips and troubleshooting
Opublikowany : 01/03/2021 7:48 pm
AM
 AM
(@am)
RE: CW1 + Formlabs
Is there a possibility to set curing time longer then 10 min?
Opublikowany : 02/03/2021 11:11 am
gnat
 gnat
(@gnat)
RE: CW1 + Formlabs
According to the firmware, 60 minutes is the max drying time: https://github.com/prusa3d/Prusa-CW-Firmware/blob/master/src/defines.h#L47
Drying and washing are limited to 10 minutes. I have a PR in to increase the max drying time, but Prusa has been studiously ignoring it since November...
Opublikowany : 02/03/2021 3:57 pm
AM
 AM
(@am)
RE: CW1 + Formlabs
@gnat
Thank you Gnat. That is really interesting.
But the mashine allows me just 10 minutes. What can I do?
AM
Opublikowany : 08/03/2021 9:05 am
gnat
 gnat
(@gnat)
RE: CW1 + Formlabs
@am
Are you using the latest firmware? I just checked mine and it let me set it to 60 minutes for the cure time:
I am running a custom firmware, but the only change is to the max drying time.
Opublikowany : 08/03/2021 4:43 pm
