1.7 rcx install failure
staticlinerich
(@staticlinerich)
Good Afternoon, I have had my SL1S for approximately a week and want to try the features in the 1.7 firmware, specifically the vat cleaning function. Elegoo has one on the Mars 2 Pro and it's pretty handy. When I enable the "beta" slider in firmware menu it immediately downloads and installs 1.7rc4. After firmware update completion and a reboot the printer hangs on the initialization screen. The only way I can recover back to 1.6.6 is to either do the  emergency USB or the power on/power off three times backdoor. Has anyone successfully been able to do upgrade to 1.7? Which method seems to be the most successful. I imagine 1.7 must be close to release. I hope. Thanks in advance.
Opublikowany : 10/05/2022 12:55 am
primefac
(@primefac)
RE: 1.7 rcx install failure
I have not, attempting a half-dozen times; it always hangs on the initialization screen.
Opublikowany : 16/05/2022 1:54 pm
primefac
(@primefac)
I contacted customer support and just got an email back from them. Officially it's a bug in the beta, which will be fixed prior to the official version release. In the meantime, we "can keep using the 1.6.6 version".
Opublikowany : 20/05/2022 10:14 am
Olivier
(@olivier-4)
How were you able to reset it? what is the emergency USB or Power On/Off method? My SL1S is stuck in the initialisation screen since installing 1.7 B4.
Opublikowany : 12/06/2022 9:48 am
primefac
(@primefac)
USB - see this thread
Opublikowany : 12/06/2022 11:37 am
