SL1 Calibration
I built my SL1 kit 2 weeks ago. I've tried 2 prints and both failed. In both cases, the plastic stuck to the FEP film even though it was perfectly clean and clear. So no part was actually printed.
I just went through calibration multiple times. Each time that it comes the the step where I have to raise/lower the tilt bed (with the resin tank at 90 degrees), the bed is always low. Also when calibration is complete and I exit the step, the tilt bed lowers (by the same amount that I had to raise it in the calibration step).
Is this normal, or if I run calibration 2 times in a row, should the second time NOT require any input to raise/lower the bed?
Thanks, Mike
Opublikowany : 30/01/2020 11:49 pm
