Im getting the "blower fan error"
Piranha
(@piranha)
Restart doesnt solve it. Im on the current firmware. Happens immediately after I press "print".
Opublikowany : 18/09/2019 11:12 pm
Piranha
(@piranha)
RE: Im getting the "blower fan error"
Opublikowany : 18/09/2019 11:20 pm
I am  also getting this error, in my case the Blower fan is definitely running t the time the error is reported,
the Dev's are looking at my issue...
If you try restarting the print, does it eventually work?
Opublikowany : 18/09/2019 11:23 pm
Piranha
(@piranha)
Unfortunately not. I restarted the print 5 times by now.
That's how I fixed it once yesterday but today it stays.
Opublikowany : 19/09/2019 12:12 am
Kaladiel
(@kaladiel)
Same here, doesnt Even work with Cover off or additional Support by blowing with my vacuum xD
Opublikowany : 29/09/2019 8:43 am
Kaladiel
(@kaladiel)
Additional info: I also sealed the duct and fan-duct connection with hotglue but the fan is running freely.
Opublikowany : 29/09/2019 8:45 am
Kaladiel
(@kaladiel)
So, 1.2.2 did NOT fix the issue, but 1.1.1 did xD
Opublikowany : 29/09/2019 7:35 pm
AndrewH
(@andrewh-2)
New fw version 1.3.0 beta is now available on request. It fixes the blower fan error.
Opublikowany : 30/11/2019 9:58 pm
2 ludzie polubili
malcinator
(@malcinator)
I installed the 1.3.0.beta0 on my SL1 it stopped the blower fan issue, shortly after I started getting a Z-Homing error. The only fix I could get was reverting back to 1.2.3
If you want to try the 1.3.0 beta it can be found here - https://prusa3d.com/downloads/others/1.3.0-beta.0.raucb - It’s beta firmware, remember that.
Opublikowany : 14/12/2019 1:40 pm
1 ludzie polubili
talktomedw
(@talktomedw)
I'm Going to try the firmware beta
Opublikowany : 18/12/2019 5:55 pm
talktomedw
(@talktomedw)
Nope! Can't flash the firmware either. Guess i just spent a bunch of money on a machine so i could print one test object. this thing is a piece of junk.
Opublikowany : 18/12/2019 8:24 pm
AndrewH
(@andrewh-2)
@talktomedw
What happens when you put the new fw on your memory stick? Do you see it listed? You go into settings/advanced/update firmware. How does it fail?
Opublikowany : 18/12/2019 9:57 pm
talktomedw
(@talktomedw)
After a machine reset I got the new firmware to take, but its still having the blower fan fail.
Opublikowany : 18/12/2019 11:29 pm
mark.attanasio
(@mark-attanasio)
Getting the error on 1.3.0.  Brand new machine. Fans are running.
Opublikowany : 05/02/2020 11:10 pm
DiRa
 DiRa
(@dira)
i had the same issue it was a broken cable at the fan side.  The black cable was loose. Is the fan running if you apply 24V on the black and red wire?
Regards
Opublikowany : 16/01/2021 2:30 pm
1 ludzie polubili
