Im getting the "blower fan error"
Restart doesnt solve it. Im on the current firmware. Happens immediately after I press "print".
RE: Im getting the "blower fan error"
I am also getting this error, in my case the Blower fan is definitely running t the time the error is reported,
the Dev's are looking at my issue...
If you try restarting the print, does it eventually work?
Unfortunately not. I restarted the print 5 times by now.
That's how I fixed it once yesterday but today it stays.
Same here, doesnt Even work with Cover off or additional Support by blowing with my vacuum xD
Additional info: I also sealed the duct and fan-duct connection with hotglue but the fan is running freely.
So, 1.2.2 did NOT fix the issue, but 1.1.1 did xD
New fw version 1.3.0 beta is now available on request. It fixes the blower fan error.
I installed the 1.3.0.beta0 on my SL1 it stopped the blower fan issue, shortly after I started getting a Z-Homing error. The only fix I could get was reverting back to 1.2.3
If you want to try the 1.3.0 beta it can be found here - https://prusa3d.com/downloads/others/1.3.0-beta.0.raucb - It’s beta firmware, remember that.
I'm Going to try the firmware beta
Nope! Can't flash the firmware either. Guess i just spent a bunch of money on a machine so i could print one test object. this thing is a piece of junk.
@talktomedw
What happens when you put the new fw on your memory stick? Do you see it listed? You go into settings/advanced/update firmware. How does it fail?
After a machine reset I got the new firmware to take, but its still having the blower fan fail.
Getting the error on 1.3.0. Brand new machine. Fans are running.
i had the same issue it was a broken cable at the fan side. The black cable was loose. Is the fan running if you apply 24V on the black and red wire?
Regards
