Revo 6 IS SUPPORTED in fw 6.0.0
Mac
 Mac
(@mac)
After first heating calibration there was a failure and then appears screen to choose different nozzle. Then heating calibration was OK.
http://www.amenit.czhttp://www.AntiviroveCentrum.cz
Opublikowany : 22/04/2024 7:19 pm
Antimix
(@antimix)
RE: Revo 6 IS SUPPORTED in fw 6.0.0
Unfortunately PRUSA confimed today that only the REVO 40W heater cartridge is supported. 😣
If you purchased the REVO 60W thinking that it will help the hi-flow and MK3.5 higher speed, than good luck... and hope than PRUSA will implement it in the FW.
They have no idea of  time plans, but the using the 60W does not pass the initial test check.
They suggested to use the 40W if I want to use the printer 😑
So today I removed the Revo 60W heater and replaced it with my old Revo 40W and it works well.
However I hope to have the 60W supported soon in order to fully appreciate the high flow.
I understand that they are in troubles for the many-to-many variants of the MK3, and the fact that now only original Prusa FW can be loaded on a Buddy board, unless you Jailbreak it an void the warranty. The mod variants that ideally must have their custom version of the FW will not work.
So they should think if reiterate the concept that whoever used a MK3 configuration mod with custom FW now will loose the warranty on new Buddy MK3.5 upgraded boards if the customer will need to install a custom FW (breaking the fuse)  in order to make it work. Another option could be that they will decide to take the ownership of all the FW variations (e.g.  all the different extruders on the market) ....
On the Einsy you could install whatever software you like, but not on the Buddy. 😉
Regards
Opublikowany : 05/05/2024 8:49 pm
