Sequential Printing using MMU3
mkatz1404
(@mkatz1404)
Hi all,
I recently assembled the MMU3 upgrade for my Prusa MK4. So far I've had no big issues, but today I was trying to print two similar parts, each of their own unique color of PLA on the same sliced file. To try and minimize tool changes and save time, I immediately thought to turn on sequential printing, but was faced with an error saying "The wipe tower is currently not supported for multimaterial sequential prints." I saw that by disabling the wipe tower, the part successfully sliced, but am concerned with what will actually happen when I print with two filaments without using the wipe tower.
I am aware I could just have two different print files, but I was curious if anyone has been able to successfully sequentially print with the MMU3 and what settings have you changed which have made it work?
Posted : 20/05/2024 7:13 pm
Ayman
(@ayman)
RE: Sequential Printing using MMU3
I think adding a 10mm brim will wipe out the previous filament color
Posted : 05/10/2024 11:59 am
Ayman
(@ayman)
The brim did not work at least in PrusaSlicer since it make all brims at first layer, but adding a 1-layer cylinder shape with a diameter of 10 mm in the meddle does the trick.
So, add your 1st object on the front corner and the second object on the opposite far corner and add the 1 layer 10 mm cylinder in the middle (obviously with the same filament color as the last object).
Good luck
This post was modified 2 years ago by Ayman
Posted : 05/10/2024 10:19 pm
bear454
(@bear454)
It would be a well-received feature in PrusaSlicer, to add additional purge/wipe strands for each filament change, in this scenario.
Posted : 17/04/2025 3:24 pm
Alienbliep
(@alienbliep)
I would like this feature too. Bambu can do it, but i think it is because of the external purging.
@Ayman I tried 3 parts and in between an 10x10x1mm block but after the first part it start to unload very very loud. Without ramming and all the other necessary steps.
The mmu even resets becasue it tried to swap filemant while it was still loaded. I am missing so settings or gcode to correctly change filament i think.
It was an painfull experience.
It should not be that hard to code an mini wipe tower in between items when sliced for sequential printing. Should only take 15x15x0.2mm at the most?
I really love prusa and their mindset, i and maybe other don't care for bigger or faster printers. It is these feature that are really nice.
I only print parts with individual colors and sometimes i have to swap 15 plates. Sometimes with an 1cm, part on it.
This post was modified 6 months ago 2 times by Alienbliep
Posted : 17/11/2025 10:04 pm
