Single Filament mode?
80sNerdBomb
(@80snerdbomb)
Just about to finish up assembling my MMU3, and i intend to load it with my 5 most commonly used filaments. However, I was wondering if there is a way, maybe by adding a Y splitter between the MMU and the extruder, to basically disable the MMU and use a single material that's not one of the ones loaded into the MMU?
I hope I explained this well enough.
Thanks.
Opublikowany : 15/11/2023 5:37 pm
ralfiboy1
(@ralfiboy1)
RE: Single Filament mode?
since there's no answer so far, have You tried using a splitter yet?
regards,  Ralf
Opublikowany : 01/06/2024 8:38 am
Zwirbel
(@zwirbel)
You can just turn off the MMU3 in the menu on the MK4 and then print "normally" as before without the MMU3.
Opublikowany : 04/06/2024 7:56 am
