MMU3 Upgrade Problem
remmert1
(@remmert1)
I have a MK3S (firmware - 3.13.3-7864) that had a working MMU2S.
I just completed the upgrade to MMU3 (re-flashed firmware 3.0.2 after the problem occured)
When I power the printer on the printer boots fine, the lights on the MMU3 go through a series of flashing (the selector never moves) and ultimately the 5th light comes on and stays green.
The MMU is enabled in settings. It also shows the Firmware version in the Support menu.
When I go into the Menu tree the Pre Load MMU option is not there. There is an option to Eject From MMU.
I can reset the MMU from within the settings.
I have checked and rechecked all of the cable connections from the MMU to the Enisy board.
Does anyone have any ideas/suggestions?
Opublikowany : 16/09/2024 3:07 am
