Print two different matereial PETG + PLA
Gianluca Maker3DDesign
(@gianluca-maker3ddesign)
Hi guys,
I want print a my project with two different material (PETG+PLA) I use prusa i3 mk3s MMU2S. Has anyone tried to print this way yet?
thanks
Napsal : 15/04/2020 7:41 am
j-martin
(@j-martin)
RE: Print two different matereial PETG + PLA
No but I’ve tried other combined materials ( Nylon and ABS). I used the setting/profiles that suited the hottest  material.
The printing worked fine. But the disaster was that the two materials didn’t stick together.
They just fell apart at the join when I lifted them off the bed at the end of the print. I guess I could have glued them together but if I was going to do that I could have just printed them separately at ideal settings for each.
Napsal : 20/05/2020 2:05 am
nim108
(@nim108)
Bonding between the two materials (PLA and PETG) is pretty horrendous, but it's possible depending on how the layers are arranged. Try with a scaled down model and then scale up if it works. The sliced gcode is pretty poor to handle this though, @nikolai-r's script is essential for multi material IMO as the temps are handled in a lot more predictable manner.
Napsal : 26/05/2020 12:29 am
ANTALIFE
(@antalife)
For people returning to this topic in the future, I did a bunch of tests with using PLA & PETG in same print and found that using different materials has a huge impact on model strength. For a typical purge volume of 250mm³ you can expect layer adhesion strength to be 1/5 of what it should be. Sadly only way to get around this is to purge crazy amounts of plastic ~2500mm³, or getting a 3D printer with at least two hotends
https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-general-discussion-announcements-and-releases/just-how-multi-material-is-the-mmu2s/
www.antalife.com
Napsal : 27/07/2020 11:11 pm
