MMU2S - when loading a filament, sometimes other filament catches the gears and moves forward a bit leaving a possibility of jamming the selector
saybobby
(@saybobby)
I've had my MMU2S (two of them), for a while.  I do get good prints for the most part, making a lot of the upgrades people generally do, including bigger ID tubes.  Now, because they have so much less friction, I generally don't have much problems loading.  Additionally, I do have a buffer so I don't have any of those types of issues either (I don't think).
My issue is that I think that sometimes, all the filament barely touches the gears, so if one filament is loading, whatever catches could potentially advance anywhere from 4 to 15 mm.  So let's say I'm loading filament 1.  While filament 1 loads, filament 3 catches and advances a tiny bit.  When filament 1 retracts, filament 3 does not retract, perhaps because there's more backpressure than pull pressure.  So when the filament changer starts moving, anywhere from going to filament 3-5 it'll jam up, because that little bit of filament is sticking out.  Honestly, this has been the biggest reason I've had any jams.  I don't usually have any other major issues besides maybe filament that needs drying and snaps, or a filament that's so curved that it misses the filament selector altogether.
Has anyone encountered this?  Does anyone have a solve?  I feel like if there was a tiny bit more friction in the tubes that would solve it, or if the filament hovered above the gear like half a millimeter more, that would also solve it.
Thanks in advance!
Bobby
Napsal : 26/12/2023 5:45 am
Miksoa Linas
(@miksoa-linas)
RE: MMU2S - when loading a filament, sometimes other filament catches the gears and moves forward a bit leaving a possibility of jamming the selector
the only big problems I see are filaments that require drying and then snap, or filaments that are so curled that they completely elude the filament selector.
spacebar clicker
Napsal : 13/03/2024 1:18 am
ratifiedtactful
(@ratifiedtactful)
Your filament seems to be tangled and having difficulty getting into the filament selector. This makes it easy to cause paper jams. Maybe I should replace it with a new set of filaments
mario games
Napsal : 16/04/2024 9:32 am
)5%3ymLavXMg%Mcf
(@53ymlavxmgmcf)
THANKS YOU
Merge Fruit
Napsal : 22/10/2024 11:46 am
Sophie Maynard
(@sophie-maynard)
Try fine-tuning the idler tension or using smaller-ID PTFE tubes near the selector to limit filament movement. Adjusting the selector’s position slightly higher or adding dry PTFE lubricant can also help reduce this issue.
brawl stars
Napsal : 26/12/2024 8:29 am
