MMU2S Filament Change Tip Issue
PrusaGuy
(@prusaguy)
Been having some level of success with using the MMU after tuning it for a year or so but its suddenly started having another issue in the middle of a print. The tip comes out like this which cannot be detected by the IR sensor once loaded. I've been having to keep snipping off the tip to continue the print. Open to any ideas of how to fix/improve the reliability of MMU load/unload???
Publié : 19/12/2020 3:25 am
john.w80
(@john-w80)
RE: MMU2S Filament Change Tip Issue
I was having a similar issue with unload failures. Here is what worked for me:
1. Remove the hotend.
2. Remove the PTFE tube and make sure that it is not damaged. Replace if so.
3. Make sure that the heatsink is screwed tight against the heater block.
4. Reinsert the PTFE tube and make sure that it is fully seated.
Publié : 19/12/2020 3:21 pm
PrusaGuy
(@prusaguy)
@john-w80
Thanks for the reply!
Pulled it apart yesterday to resit the PTFE tube and found the collet was moving with the tube. Have now redone and put a collar under the ensure no movement. Started working well but now white PLA seems to be still having the issue. Might try new PTFE tubing but literally replaced this one a month ago 😕
Publié : 20/12/2020 1:26 am
ANTALIFE
(@antalife)
Had this issue as well, changed the printer FW to handle it better:
https://www.antalife.com/2020/08/project-mmu2s-filament-diameter.html
Also here are some other mods (software & hardware) that helped with reliability:
https://www.antalife.com/2020/07/project-prusa-i3-mk3s-mmu2s.html
www.antalife.com
Publié : 25/12/2020 2:40 am
