Every print starts with "remove old filament"
Marco
(@marco)
Membre
Hey guys,
I'm having a bit weird behaviour during my MMU prints.
Every time I start a MMU print, after the bed leveling the extruder moves up a bit and I got the message that I have tor emove the old old filament and press the knob afterwards.
There is no filament in the extruder. I just could press the knob and the printer starts to load the filament without any big issues.
In case I do an single coler print, the printer asks wich filemant I would like to load and erverything ist fine. It also happens during a MMU print.
I took a look at the sensors and every senser is on "0"
I reinstalled the prusa slicer as well without any changes.
Do you have an idea?
Marco
Publié : 15/08/2023 3:43 pm
gudnimg
(@gudnimg)
RE: Every print starts with "remove old filament"
Hi, I just want to mention that a fix for this is coming in 3.13.1: https://github.com/prusa3d/Prusa-Firmware/pull/4332 it's not a new issue but seems more people were seeing it on 3.13.0 so we finally found the source of the problem and fixed it.
Publié : 19/08/2023 11:13 pm
Marco a aimé
Marco
(@marco)
Membre
Thanks a lot for your Info.
I'm looking forward for the next update.
Publié : 20/08/2023 3:59 am
michalkoj
(@michalkoj)
I was able to get around this bug by temporarily unplugging the Super PINDA and plugging in the old PINDA to reactivate the setting "PINDA Calibration" and turn it off. When I plugged the Super PINDA back in, no more remove old filament message, second bed level or grinding at the beginning of purge.
Publié : 22/08/2023 1:36 am
Roy
 Roy
(@roy)
I solved this by doing a factory reset on both, MMU and the printer after I flashed both new frimwares.
You will loose all settings and have to run through the wizard again and also need to do first layer calibration for all sheets.
It would be clever to note your live Z values for the different sheets to set them up quickly again.
Took me 45min in total
Publié : 12/09/2023 9:11 am
Hello
(@hello)
Posted by: @michalkoj
So u replaced supr pinda with normal pinda
Publié : 12/09/2023 9:37 am
michalkoj
(@michalkoj)
Only temporarily to reveal the setting “pinda calibration” and turn it off. The SUPER pinda does not need calibration so this setting will not show with it installed.
The factory reset clears the calibration values in the eeprom but turning off pinda cal lets the system ignore those values instead. This explains why this issue in GitHub says mk3s+ is unable to reproduce because they ship with the SUPER Pinda and never had cal data stored or the setting turned on like mk3/s.
Posted by: @hello
Publié : 12/09/2023 1:04 pm
Hello
(@hello)
Posted by: @hello
Big brain thanks for the info
Publié : 12/09/2023 7:56 pm
gudnimg
(@gudnimg)
FW 3.13.2 RC1 has been released and includes a fix for the issue in case others stumble on this thread. No need for factory reset.
https://github.com/prusa3d/Prusa-Firmware/releases/tag/v3.13.2-RC1
Publié : 12/09/2023 8:12 pm
Hello
(@hello)
Posted by: @gudnimg
Im a bit weary of these new firmwares at the moment could you let us know of any problems you find
Publié : 12/09/2023 8:32 pm
René
(@rene-3)
On github, you can keep track of the problems there are with firmwares on a daily basis.
Here they are.
Publié : 13/09/2023 6:32 am
Hello
(@hello)
Posted by: @rene-3
Here they are.
I know there currently aren't any for this firmware.so was asking if anyone had any problems so far. Appreciate the help though
Publié : 13/09/2023 8:58 am
Oba
 Oba
(@oba-2)
Membre
I'm stuck in 3.13.0. I dont know why but my printer is not accetping firmware updates. even downgrades. Is there another workaround to fix this?
Publié : 20/06/2024 5:40 pm
