Printing a 100% TPU part without changing filament?
ron-f
(@ron-f)
Hello,
I print from time to time some part with low shoreA (70, 80). I'm interested in the MMU2S for other purposes. Then if I have the MMU2S on my printer installed because I want it, would a 100% TPU part without changing filament would be affected? If yes what can run me into troubles?
As I understand the system, it should be trouble free as once the filament is engaged in the hotend, the behavior is the same as for a printer without MMU2S.
I ask to owners before buying.
Opublikowany : 19/05/2019 6:40 pm
RE: Printing a 100% TPU part without changing filament?
you can try re calibrating the feed for the mmu2 Feeds, to cater for the flexibility of the TPU, they will probably need to feed a little lomget than more rigid filaments.
Opublikowany : 19/05/2019 10:22 pm
ron-f
(@ron-f)
Glad to hear that.
I also read (somewhere in this forum) that I can simply disconnect the last PTFE tube and engage directly in the extruder the flexible filaments to quickly bypass the MMU2S.
I will certainly purchase one in a near future.
Opublikowany : 26/05/2019 10:22 pm
