Push Knob and Load New Filament
DomCat
(@domcat)
While printing with multiple or even a single color multiple times throughout the print the extruder moves to the side, unloads the filament and starts beeping asking to push the knob and reload the filament. How can I fix this issue?
Opublikowany : 30/01/2023 4:43 pm
Your extruder filament sensor may be at the root of this.  Check there are no fine strings, debris or dust in there and that it is not jamming.
Cherio,
Opublikowany : 31/01/2023 10:09 am
DomCat
(@domcat)
RE: Push Knob and Load New Filament
Where would these strings be? It still prints and extrudes for some time before it stops so I don't see how there'd be strings affecting it?
Opublikowany : 31/01/2023 2:29 pm
Anywhere they might obstruct sensor operation - spiderweb fine strings turn up in the oddest places and sometimes they jam things.
Opublikowany : 01/02/2023 4:20 am
Robin
(@robin)
This is the "normal" behavior when filament runout is detected. When the MMU2 is installed the filament runout is trigged by the FINDA and not by the IR-sensor in the extruder. So most likely you have the FINDA placed a little too high so it sometimes triggers the runout see: https://help.prusa3d.com/article/finda-setup-and-troubleshooting_2250 for help.
Opublikowany : 03/03/2023 10:41 am
