Jammed filament between carriage and tubes
So not quite sure how I have managed it (but I have), I have a tiny piece of what I assume is some PETG filament jammed between the carriage and the tubes - to the point where the carriage cannot move back/forth. It is not attached to the "full" filament it must only be a piece that is a couple of mm long (if even that).
What's the easiest way to remove the carriage to get between the carriage and the tubes - is it just remove the motor, remove the screws locking the spinning thread from the carriage and then try and pull the carriage out or is there a more efficient method for doing it?
Thanks for any help anyone has!
Opublikowany : 19/01/2022 12:32 am
