How to force Slicer to make supports with different filament (different slot)
SledgehammerPL
(@sledgehammerpl)
I'm absolutely beginner.
I try to print figures like mushroom, so there have to be lot of supports. But how change support material? I can choose that object would be printed from any slot, but supports are made also from the same slot. How to choose slot for support material, eg. 5th slot which is filled with BVOH 😀
Este debate ha sido modificado el hace 6 years 2 veces por SledgehammerPL
Respondido : 20/10/2020 5:23 pm
vintagepc
(@vintagepc)
Miembro
RE: How to force Slicer to make supports with different filament (different slot)
1. Make sure supports->interface layers is set to something >0
2. Under Print settings->multiple extruders, change the "support material INTERFACE extruder" setting (last one, there are two that are similarly named) to the desired extruder.
Respondido : 21/10/2020 11:57 am
AB
 AB
(@ab-2)
@vintagepc, is this on the printer or within the slicer?
Respondido : 02/02/2021 9:19 pm
Robin
(@robin)
Slicer. Just use the presets for soluble interface or supports...
Respondido : 05/02/2021 2:10 pm
Maddie Corry
(@maddie-corry)
Miembro
This removes the wipe tower, is there a way to make the supports one material while having the wipe tower?
Respondido : 17/06/2025 6:39 pm
