All lights flashing at completion of print.
Print McPrinty
(@print-mcprinty)
Has anyone else see this: Almost every time a print finishes I find the MMU with all the lights flashing and the filament still loaded. The screen will say the "MMU needs attention" and the bed will still be heated.
MK2.5s with the MMU2s running the latest firmware.
Postato : 08/03/2020 2:20 pm
Bristol Public Library
(@bristol-public-library)
RE: All lights flashing at completion of print.
Mine just did that, actually it was blinking before the print too, and reset the MMU.
TJ
Postato : 10/03/2020 6:37 pm
Mary Tillios
(@mary-tillios)
I have all the lights blinking and before printing. I find nothing wrong with that. This does not affect performance.
Postato : 11/03/2020 2:16 pm
Posted by: @michael-w19
These errors are often caused by a badly adjusted or dirty sensor. Remove any remaining filament and readjust the sensor with a piece of filament. On the lcd screen you can see the status: 1 is loaded, 0 is not loaded.
Postato : 11/03/2020 2:49 pm
Mine got worse this morning, flashing multiple times in a row, could barely start a print. I found the following post regarding blinking lights and power connections:
https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-hardware-firmware-and-software-help/mmu2s-keeps-resetting-red-green-leds-flashing-at-once/#post-158344
I don't know if it is fixed, but I did wiggle the wires to reseat everything, and it has not given me a blinking error this afternoon.  Hope it helps
TJ
Postato : 11/03/2020 7:15 pm
