Removed MMU2-Octoprint stopped working
flounder
(@flounder)
I physically removed the MMU2S from my MKS3.  I powered it back up, and it gave me an "autoload filament" option, which I did, and the filament extruded.
So I logged into OctoPrint, which I have been using since I got the printer, it connected, but now it won't let me select a file I've uploaded, and it won't give me a temperature graph.  I have checked that all the USB cables are plugged in properly, and power-cycled the RasPi, but no luck.  Removing the MMU2s involved removing four wires (I didn't remove them, a friend was helping since I have some serious mobility problems).  Everything seems to be fine, but no printing is happening.  It might be an OctoPrint problem.  I am going to post there
Napsal : 02/12/2020 10:57 pm
Lize
 Lize
(@lize)
RE: Removed MMU2-Octoprint stopped working
Did you change your printer profile in Octopi, not sure of all the differences but theres number of extruders which would need setting to 1 rather than 5.
Napsal : 03/12/2020 12:45 am
flounder
(@flounder)
@lize
I have no idea how to do that.
Napsal : 05/12/2020 12:03 am
@flounder
Octoprint changes:
Settings
Printer profile
Edit printer profile (Action)
Hotend & Extruder
Set the Extruder value to 1
Remove the data and the power cable from the MMU2:
(remove the violet marked plugs)
Napsal : 05/12/2020 12:48 am
flounder
(@flounder)
@karl-herbert
No, I meant I have no idea how to change the octopi settings
Napsal : 05/12/2020 12:53 am
@flounder
you don't have to change anything on the octopi system, but as I just listed in the gui octoprint:
Napsal : 05/12/2020 1:00 am
Lize
 Lize
(@lize)
Apologies for causing confusion I should have said Octoprint.
Napsal : 05/12/2020 3:07 am
